danger New Member 23 Member For: 11y 9m 3d Posted 24/12/18 02:37 AM Author Share Posted 24/12/18 02:37 AM Thanks guys much appreciated. So if I use e85 the pump will be too small ? Or does the same apply for petrol also? For around the 450rwkw mark? Thx. Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668597 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 5d Gender: Male Posted 24/12/18 11:21 AM Share Posted 24/12/18 11:21 AM I reckon your pump would go very close to 450rwkw on 98.Just remember that E85 requires 30% more fuel volume for the same power. Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668636 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 18d Gender: Male Location: Perth Posted 24/12/18 02:17 PM Share Posted 24/12/18 02:17 PM What is the pumps rating at 4 bar. I make my power on E85 with as bout 300l/h. So should go 450 on E85. Plenty on 98 Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668643 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 14d Gender: Male Location: Adelaide Posted 24/12/18 11:19 PM Share Posted 24/12/18 11:19 PM ID1000’s will go 550rwkw with 4bar pressure and 95% DC with 0.85 lambda target on E85 That pump is an intank pump and iirc isn’t a high pressure one so it’s capable supply is limited by the head pressure that it will need to work at ( boost pressure on top of delta 4bar ) so it’s on paper limitations will be vastly different to actual ability either way it'll be a great pump to use as a lift pump to an aftermarket surge tank arrangement that you’ll need for a B series tank Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668647 Share on other sites More sharing options...
danger New Member 23 Member For: 11y 9m 3d Posted 28/12/18 07:17 AM Author Share Posted 28/12/18 07:17 AM So use this pump as a lift pump for a surge and single 044 or would two 044s be the go? Or is two overkill? Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668775 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 18d Gender: Male Location: Perth Posted 28/12/18 08:09 AM Share Posted 28/12/18 08:09 AM If running E85 dont use 044 Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668777 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 5d Gender: Male Posted 28/12/18 08:09 AM Share Posted 28/12/18 08:09 AM Why do people keep wanting to use 044's? They're old sh*tty pumps that don't handle ethanol well and are noisy as hell! They were cool and the go to pump like 15 years ago in the VL scene when 300rwkw was an absolute weapon Why not setup a proper surge, either in-tank or out with some decent Walbro or Deatschwerks pumps? Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668778 Share on other sites More sharing options...
danger New Member 23 Member For: 11y 9m 3d Posted 28/12/18 11:39 AM Author Share Posted 28/12/18 11:39 AM Single walbro 525 intank? Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668787 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 14d Gender: Male Location: Adelaide Posted 28/12/18 12:06 PM Share Posted 28/12/18 12:06 PM A single Walbro 525 is good for ~ 470/480rwkw @ 0.8 lambda with upto 25psi ontop of delta on E85 and is a great intank option but will require an aftermarket FPR to manage the High pressure it operates at. Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668788 Share on other sites More sharing options...
danger New Member 23 Member For: 11y 9m 3d Posted 28/12/18 12:11 PM Author Share Posted 28/12/18 12:11 PM Thankyou jet. And will they fit standard hanger? Just swap over pumps and away you go? Link to comment https://www.fordxr6turbo.com/forum/topic/94477-will-i-need-more-fuel/page/2/#findComment-1668789 Share on other sites More sharing options...
