Weird fuel issue
adams355
  • Member For: 7y 8m 30d
Yea I put it up soon. It was just chucked together by me so the tuner did a great job to work with what he had. Has turbosmart actuator as well 10psi spring.
Edited by adams355
Ok how does this look.
Race works 1000cc injectors
Old nizpro tube & fin with pipes
Turbosmart actuator 10psi spring
255 fuel pump
Outlaw cat convertor
Very hot yesterday, needs valve springs, tuned on pcmtec, valve springs and fuel pump for flex at the end of the year. Still a bit more in it on 98. Was done on a budget budget. Tuner had to work with what he had. Sorry sideways pic. 337rwkw@16 @5000
Edited by adams355
  • Trust me bro...tbh ;) 8===}
  • Member For: 10y 2d
What other exhaust and intake mods do you have?
It looks like there is something stopping it from waking up a bit earlier but it could just be in the tune.
340 is still a good number to be driving around on and when you get the valve springs done it'll go heaps harder.
Summer and boost do not go well together.
Just standard with a pod. Standard exhaust just cat. I tried a bigger exhaust off dump to merge but lost throttle response which is annoying because its a daily. Boosts quicker now than it ever did. 200000 km motor, turbo, auto. Its in decent knick though.
  • Bronze Donating Members
  • Member For: 8y 5m 16d
does look a little lazy but power figure is pretty good.
if it were me id spend a few hundred on a box and intake setup. XR6 turbo developments do one that's  bolt on or you could make one your self. Will make a world of difference to temps the filter is getting etc etc
Edited by MBAF
The cold air intake made a substantial difference to my cars and would be one of the first mods to do pretty much, as far as effectiveness goes toward the current setup.
Can't be to lazy 700nm@3300rpm. Lots of timing in it early. Similar to other forced dyno sheets. It has a pod in a housing which gets air from under headlight. Don't want to do the battery thing. Its a daily so can't get to carried away lol. Its had three tunes in it. This one is night and day compared to the others.
