HI PSI Member 1,586 Member For: 18y 9m 10d Gender: Male Location: Central Queensland Posted 11/12/18 10:32 PM Share Posted 11/12/18 10:32 PM (edited) Just got send these... Edited 11/12/18 10:33 PM by HI PSI Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,291 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 11/12/18 10:42 PM Share Posted 11/12/18 10:42 PM your car, Steve? Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 9m 10d Gender: Male Location: Central Queensland Posted 11/12/18 10:48 PM Author Share Posted 11/12/18 10:48 PM I wish... Another beast that's is prowling the streets... Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,291 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 11/12/18 11:09 PM Share Posted 11/12/18 11:09 PM nice work do you know anything/much about it? Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 9m 10d Gender: Male Location: Central Queensland Posted 11/12/18 11:40 PM Author Share Posted 11/12/18 11:40 PM (edited) Old members would remember the car.... One of, if not the most advanced Barra's around.. It has had considerable modifications since it was purchased from the previous owner. There is a 88 page thread (from the previous owner) on here somewhere... Btw, the other car in video was a R33 GTR. Edited 11/12/18 11:42 PM by HI PSI Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,291 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 12/12/18 02:12 PM Share Posted 12/12/18 02:12 PM yeah, I've read all of the good threads on this forum I'm sure I've read about this car, but it seems a lot as changed and I'm looking for that information, I guess.... Link to comment Share on other sites More sharing options...
D4N Donating Members 35 Member For: 6y 6m 5d Posted 13/12/18 02:56 AM Share Posted 13/12/18 02:56 AM Weapon! If this is the car I think it is I was only reading the post related to it yesterday. If it is, great to see it on the road after all the trouble the gent had with it and the battle to get it running. I hope he is enjoying it!! Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 9m 10d Gender: Male Location: Central Queensland Posted 13/12/18 05:04 AM Author Share Posted 13/12/18 05:04 AM (edited) The "sound" and its source could not be identified. So he decided to run it and "see what happened". It's still running fine, even after copping a hiding.. 15 hours ago, k31th said: yeah, I've read all of the good threads on this forum I'm sure I've read about this car, but it seems a lot as changed and I'm looking for that information, I guess.... When he purchased the car, the engine was in pieces. The compression was lowered, and alloy rods were fitted. The exhaust manifold was changed and the Precision was replaced with a Gtx 91 mm turbo (from memory). I believe that a 5" dump and exhaust was also fitted and a bigger Plazmaman intercooler. After a little driving, the 9" housing was distorted to such an extent that there was nearly 10 mm difference at the diff center flange. A new moly housing was fitted, and much shorter gears installed. From what I gather, the rest remains the same... The car still has more left in it and it will be getting more boost soon.. Edited 13/12/18 05:06 AM by HI PSI Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 9m 10d Gender: Male Location: Central Queensland Posted 13/12/18 12:06 PM Author Share Posted 13/12/18 12:06 PM A bit more detail.... Ba typhoon Engine Auscrank billet crank 3.6L R&r billet conrods Cp pistons Billet tool steel main caps 14.3mm head studs Honda k20 dual valve springs sr20 titanium retainers Ferrea valves Mechanical fuel pump+Magna fuel pump 6xMoran injectors 6x ID2000 Hypertune intake 6boost exhaust Gen2 gtx5533r 91mm ARE intercooler 5” exhaust split into twin 4” at diff Jesel modular rockers Dry sump Motec m800 ecu Motec CDI ignition Motec data logging dash Transmission T56 magnum built by mal woods. Carbon synchros,billet shafts etc. Race products chrome moly diff housing LSD Detroit locker 35 spline axles 4 link/coil overs etc all mounted to factory mounting points so it passes roadworthy. 315/60 15 on billet specialties wheels. Andra spec 6 point cage with mod plate. Parachute Brembo front brakes and smaller brakes to suit front runners. The car has about 105,000km on it. The body is straight but the paint has a few scratches etc from spending its whole life in a workshop. 1524rwhp on pump e85 with full exhaust and air filter etc. Comes with methanol tune but it’s never been turned right up on methanol to get a power figure. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,291 Member For: 16y 10m 25d Gender: Male Location: Melbourne Posted 13/12/18 12:22 PM Share Posted 13/12/18 12:22 PM oooooooooooo delicious Link to comment Share on other sites More sharing options...
