Hede267 New Member 12 Member For: 6y 4m 23d Posted 08/12/18 04:02 AM Author Share Posted 08/12/18 04:02 AM Hey fellas so me and my mates done the trans swap and now it wont start cause of the fault codes coming up can we attack that with a proper scaner tool or does it have to be sent into ford ? Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667917 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 08/12/18 04:13 AM Share Posted 08/12/18 04:13 AM You get the right trans mate? You can't put an fg trans into a bf etc cos the tcm is different. What codes are being shown? You can clear codes with a scan tool or tuning tool but I have a feeling that this isn't going to help here. @NA_TURBO loves getting his stuff relinked by ford. I'm sure he'll share his knowledge when he sees this. Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667918 Share on other sites More sharing options...
Hede267 New Member 12 Member For: 6y 4m 23d Posted 08/12/18 04:29 AM Author Share Posted 08/12/18 04:29 AM Transmission fault and system cons fault and definitely same tansmisson both fgs Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667922 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 08/12/18 04:40 AM Share Posted 08/12/18 04:40 AM I think system comms is when you give it to ford to flash. I've never had to deal with that so someone else can confirm what you need to do. If it's tuned then you'll wanna make sure that the tune is still intact after or you'll be up the sh*t. Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667926 Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 6m 20d Gender: Male Location: Mildura Posted 08/12/18 05:06 AM Share Posted 08/12/18 05:06 AM If you're trying to swap a ZF from another car into yours, you'll need to put your TCM module into the new box otherwise it won't work. Not sure if Fraud is able to flash the TCM to your car. Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667928 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,301 Member For: 10y 2m 30d Gender: Male Location: South Australia Posted 08/12/18 05:15 AM Share Posted 08/12/18 05:15 AM From what I understood you can swap the same models without swapping the actual tcm unit. I think you couldn't swap different models because the operating system was different. @rollex will know lol. Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1667930 Share on other sites More sharing options...
Hede267 New Member 12 Member For: 6y 4m 23d Posted 08/01/19 05:22 AM Author Share Posted 08/01/19 05:22 AM (edited) hi again fellas so I have swapped the old tcm onto the new transmission now the transmission fault code has gone just the system fault code still appears , my mate ended up getting one of his friends that owns a shop to use the scanner tool to scan and he is getting shifter module fault , hes tried clearing the code but just appears again , anyone might one what the issue is ? thanks in advance Edited 08/01/19 05:25 AM by Hede267 Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1669586 Share on other sites More sharing options...
ilk Is on holiday from communism Member 1,282 Member For: 6y 3m 26d Gender: Female Location: Victoria Posted 09/01/19 08:48 AM Share Posted 09/01/19 08:48 AM This will help FG ZF 6hp26 6 speed auto.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1669848 Share on other sites More sharing options...
Hede267 New Member 12 Member For: 6y 4m 23d Posted 09/01/19 10:25 AM Author Share Posted 09/01/19 10:25 AM Thanks for that kittens ??? Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1669863 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 1d Posted 09/01/19 11:47 AM Share Posted 09/01/19 11:47 AM There's a white sticker on the side of the gearbox with a code on it. you have to have the same code on the new gearbox or it won't work .Only ZF can recode the megatronics unit, ford can't. If you can find the right gearbox you can (with the car on a hoist) plug the new gearbox into the car & check that you can clear the codes (the wires are long enough to reach the other gearbox) If your new gearbox is good the codes will clear & stay away. This takes the guess work out of 'will it fix it' before you go to all the trouble of fitting it Link to comment https://www.fordxr6turbo.com/forum/topic/94436-zf-6hp26-transmisson-oil-mix-with-water/page/2/#findComment-1669877 Share on other sites More sharing options...
