Orangeback New Member 2 Member For: 6y 8m 15d Gender: Male Location: New Zealand Posted 16/11/18 06:08 AM Share Posted 16/11/18 06:08 AM (edited) Hello Im a new f6 owner and I've got a dyno tunes 2012 f6 with 379 rwkw , it is hunitng for power at top end, could this be a coil breaking down? , or is it an injector thing ?, or valve ? fuel pump delivery? I am unsure of any of the modes to car , believed it was to be stock with remap tune, but unsure, as the tune shop had no records to what they had done other than the dyno sheet. any suggestions to why ? thanks in advance Edited 16/11/18 06:12 AM by Orangeback Link to comment https://www.fordxr6turbo.com/forum/topic/94399-f6-hunting-at-top-end/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,589 Member For: 17y 2m 28d Gender: Male Location: Melbourne Posted 16/11/18 06:20 AM Share Posted 16/11/18 06:20 AM Well, it won't have made 379kW with a stock remap tune only, so there's definitely some other mods on the car. It could be the coils or spark plugs. They're the easiest things to check. It could also be the oxygen sensor. Another simple thing to check Contact the tuner of the car and get them to look at it, as a simple resort, after you've checked the above basic things. If they were able to tune it, they should be able to diagnose it reasonably quickly. Link to comment https://www.fordxr6turbo.com/forum/topic/94399-f6-hunting-at-top-end/#findComment-1667055 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 9d Gender: Not Telling Posted 16/11/18 06:59 AM Share Posted 16/11/18 06:59 AM 33 minutes ago, k31th said: Well, it won't have made 379kW with a stock remap tune only, so there's definitely some other mods on the car. Yes. 33 minutes ago, k31th said: It could be the coils or spark plugs. Probably is. 33 minutes ago, k31th said: It could also be the oxygen sensor. Definitely not going to affect top end power. 34 minutes ago, k31th said: Contact the tuner of the car and get them to look at it...after you've checked the above basic things. Couldn't have said it better. 47 minutes ago, Orangeback said: Hello Gday 47 minutes ago, Orangeback said: the tune shop had no records to what they had done other than the dyno sheet. any suggestions to why ? Bunch of slackers that don't keep records? Maybe they didn't modify it and they just tuned it? Just chuck in a new set of gas plugs so yer gap is right and if that doesn't fix it then swap out the coils for a genuine set. Link to comment https://www.fordxr6turbo.com/forum/topic/94399-f6-hunting-at-top-end/#findComment-1667058 Share on other sites More sharing options...
