tazzanz Donating Members 573 Member For: 9y 4m 28d Gender: Male Location: NZ Posted 08/11/18 03:24 AM Share Posted 08/11/18 03:24 AM Hi guys Can anyone confirm if I can use the generic XR6 Kit or there is a Territory specific one? I have heard you need an adapter for the block side on the Territory? Cheers Pic of new tow car 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,072 Member For: 16y 8m 20d Gender: Male Location: Melbourne Posted 08/11/18 03:36 AM Share Posted 08/11/18 03:36 AM as far as I know, you can use an XR6T one... but I have not been in a territory engine bay to confirm 100%... 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 3d Gender: Male Location: Perth Posted 10/11/18 12:24 AM Share Posted 10/11/18 12:24 AM (edited) Totally different. Call these guys. I got a great kit from them. All black. https://www.gjdrivelines.com.au/ Edited 10/11/18 12:27 AM by arronm Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,072 Member For: 16y 8m 20d Gender: Male Location: Melbourne Posted 10/11/18 12:26 AM Share Posted 10/11/18 12:26 AM OK, so it's the same engine, same turbo setup on the hot-side, to the XR6T... then how/why is it different? enlighten me, as I'm curious as to why/how this would be done thanks in advance. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 3d Gender: Male Location: Perth Posted 10/11/18 12:37 AM Share Posted 10/11/18 12:37 AM Its the oil pressure sender setup and the location of the trans cooler. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,072 Member For: 16y 8m 20d Gender: Male Location: Melbourne Posted 10/11/18 12:39 AM Share Posted 10/11/18 12:39 AM ok, thanks mate... weird that they'd change it, but OK... Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 3d Gender: Male Location: Perth Posted 10/11/18 12:41 AM Share Posted 10/11/18 12:41 AM AWD has transfer case... 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,072 Member For: 16y 8m 20d Gender: Male Location: Melbourne Posted 10/11/18 12:42 AM Share Posted 10/11/18 12:42 AM and it's directly underneath the intake manifold? makes sense... 1 Link to comment Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 9y 4m 28d Gender: Male Location: NZ Posted 14/11/18 01:56 AM Author Share Posted 14/11/18 01:56 AM Cheers Aaron thought they might be different, Although think I’m just going to remove stock filter screen and run the stock hardline and keep up with oil changes. Link to comment Share on other sites More sharing options...
BeerTurbo Donating Members 241 Member For: 6y 7m 21d Posted 30/03/19 03:51 AM Share Posted 30/03/19 03:51 AM (edited) Auto cooler sits exactly where your oil pressure sensor is. The oil feed/filter that goes into the block is the same, however instead of having a adapter for the banjo/oil pressure sensor it has an end cap, just for securing the banjo. directly of the terry oil line there is a fitting where the oil pressure sensor sits. I have removed my stock auto cooler and placed a normal xr6 oil pressure sensor threaded fitting onto the block fitting and using a standard braided oil feed for turbo. heres a picture I took, its quite bad but you can just see the oil fitting and the territory sideways oil pressure sensor. Edited 30/03/19 03:57 AM by BeerTurbo pictures and stuff 1 Link to comment Share on other sites More sharing options...
