  • Member For: 12y 3m 28d
Hi guys,
After filtering through all the misfire related topics and find very few threads with actual resolutions I thought I'd start a new one.
Basically my 09 FG G6e turbo started misfiring at WOT when at the strip the other night. 400rwkw running E85 to give an idea of mod level. The thing had done it before, when it did I took it back to the tuner where it got a service and retune and came out happy as. Has been running sweet for about 6 months now but the problem has returned and is far worse. Essentially when I am on hard boost it sounds like it has a very bad misfire and no power obviously. Originally it was just under WOT but on the way back from the track it got worse, occasionally misfiring while.cruising at 100kph and but the time I got home (100km later) struggling to idle without misfiring. With slight throttle it runs smooth as so I'm thinking it has to do with ignition as the extra voltage with slight throttle will help spark but as soon as any fuel or boost is dumped into the engine it misfires again.
I am yet to talk to my tuner (will today) but will update this post, through to resolution so hopefully it can help out the next victim. Keen to here any ideas or similar stories.
Cheers, Joel
Edited by Ozkart13
https://www.fordxr6turbo.com/forum/topic/94368-fg-misfire/
  • 1 month later...
  • To Loud
  • Member For: 13y 6m 21d
Sounds like @Ozkart13 didn't come through with the goods as he promised.
Joel has left yet another unsolved mystery on our forum.
Joel did you get it fixed?
https://www.fordxr6turbo.com/forum/topic/94368-fg-misfire/#findComment-1668046
  • 1 month later...
Fair callout @masda74, I let this slip. To be fair though I only rectified the issue on Friday.
My mechanic replaced the coils and plugs about 2 months ago as discussed. This fixed the problem as far as I could tell, it was idling fine and under some half pulls on e85 it performed fine. Happy days, I thought "all fixed, I'm not updating that post though". 😉
Changed to 98 and the car had been running fine for a good 2 months. Under full load, about 17psi, no issues whatsoever. Until...
Changed back to e85 last week, pulled onto the motorway, planted it and on the very first pull back on e85 the dreaded misfire returned. A couple more pulls confirmed it and I had a head in hands moment.
Next morning over some bacon and eggs I remembered one thing we didnt do, gap the plugs. A trip back to my local mechanic, plugs regapped from 1mm to 0.7mm and the engine is running 100%. But now I think 4th is slipping... 😣😅 Sorry bout the long version. Hopefully it helps.
Short version = new coils and new plugs gapped to 0.7mm = win
  • Like 2
https://www.fordxr6turbo.com/forum/topic/94368-fg-misfire/#findComment-1672502
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 11d
  On 04/11/2018 at 9:29 PM, k31th said:
idea: coils.
Expand
that'll be $20 (to the forum, not me) thanks haha
https://www.fordxr6turbo.com/forum/topic/94368-fg-misfire/#findComment-1672506
  • Member For: 10y 4m 22d
  • Gender: Not Telling
  On 04/11/2018 at 9:36 PM, Puffwagon said:
Idea: plugs are rooted.
Expand
Expand
Now now keefy boy, that's my beer you're trying to drink.
https://www.fordxr6turbo.com/forum/topic/94368-fg-misfire/#findComment-1672514
