Camsta97 Member 26 Member For: 6y 7m 17d Posted 29/10/18 02:39 PM Share Posted 29/10/18 02:39 PM Not sure if this would work or not, but I've jacked the car up this afternoon and spinning the wheels with the car in park is causing the main centre diff bush to bang up and down, now from what I can see I would be able to easily access and change that bush if I was to cut a hole in the spare wheel well to gain access? will this work ? because I only need to change the main rear one and id rather not have to pull out the entire cradle Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 9m 25d Posted 29/10/18 07:52 PM Share Posted 29/10/18 07:52 PM Yes it will work, but... (Iv'e seen it before but it looks like crap & I dont know if it will cause problems with a roadworthy) Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,147 Member For: 16y 9m 10d Gender: Male Location: Melbourne Posted 29/10/18 11:11 PM Share Posted 29/10/18 11:11 PM yep, it works... weld the piece back in or with a hinge mechanism or something (if you want to use it again). It's not a concern if you cover it with the sound deadening stuff underneath haha Link to comment Share on other sites More sharing options...
Camsta97 Member 26 Member For: 6y 7m 17d Posted 30/10/18 01:00 AM Author Share Posted 30/10/18 01:00 AM Hahah sweet, what's the chances of the big bolt breaking apparently it's common and I'm assuming if I snap it whole cradle gotta come out anyway? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,147 Member For: 16y 9m 10d Gender: Male Location: Melbourne Posted 30/10/18 02:15 AM Share Posted 30/10/18 02:15 AM If you have a lot of power and you put in a solid/hard bush, then yes, it can break the bolt. But with a bit of "softness" in the bush, then the bush takes the forces mostly and it gets a bit buggered quickly. The weld-able twin bush diff hat is the way to go to fix this problem completely. Link to comment Share on other sites More sharing options...
