Dealer told me not to service my Zf 6sp - opinions?
cm.
  • Member For: 9y 10m 4d
I have no hoist. I'm thinking of dropping the pan one morning and then running it out to a welding place to get a plug welded in. Remaining drops and refills will be much quicker then.
  • New Member
  • Member For: 6y 5m 1d
22 hours ago, El Andrew said:
You don't need any extra equipment - the flush is basically just several fluid changes, but running the car and cycling through gears between each change to mix the new fluid with what stayed in the torque converter.
I'm going to have a go at this myself in the next few weeks.
True, but my understanding is that this wasn't as good as using one of the machines at the workshop. I guess if you drop the pan enough it's probably about the same..
  • Member For: 9y 4m 18d
Been running nylon in my non turbo ZF with 330+rwkw for 2 years and no problems whatsoever.
  • 2 months later...
  • Inactive Members
  • Member For: 11y 7m 3d
Hi Guys,
Just did the ZF filter/Lifeguard fluid change on the weekend.
1 word of warning, the ZF fill plug is scary tight, make sure you can loosen the plug before undoing any bolts, or you will be left with no way of refilling an empty trans.
  • Like 2
