Turbo play
HOTXR6T
  • Member For: 6y 5m 27d
Hi I have been fitting a box over my pod air cleaner this afternoon, and while I had the 3" hose of the turbo I spun the turbo, spins fine, but I noticed it has some play in it. It's not making any noise, I was wondering how much play is normal if any and if it's not, do they run long after showing wear? She has done about 145000 km.
  • Trust me bro...
  • Member For: 9y 11m 17d
Mine had some play at 138xxxkm when I bought it and after being turned up it started making bearing noises within 10xxxkm or so I reckon.
  • Bronze Donating Members
  • Member For: 10y 9m 19d
generaly a bit of up & down movement is acceptable (as long as it doesn't touch) but in & out movement is bad. These things don't last forever & when we speed (increase boost) them up we shorten there life.
  • Thanks 1
  • Member For: 7y 8m 14d
Mine has a little movement in/out and side to side. Its still the same and fine after 10,000 kms plus at 14psi. Had to replace the wife's diesel captiva (worst car ever, I couldn't change her mind) turbo a little while back and it was fine for 100,000km with 2 oil changes lol.. When it started to seize would still run but there was a cm play at every angle lol. Use good oil and change the turbo oil filter situation. Engine flush the oil as well if you know its history.
Edited by adams355
Thanks guys, it's may a mil or 2 sideways movement. But I did not know if it was allowed any movement at all. I am driving her to Alice springs next weekend 500k each way, the speed limit here is 130 kph and the highway patrol don't bother anyone doing 139 kph so it's pretty much cruise control for 3 and a half hours.
  • Dropping a turd
  • Member For: 17y 2m 19d
It has to have clearance to allow for expansion  when hot.
Park in a garage and turn car off and listen to run down. That will tell you the condition.
