DRL07 New Member 3 Member For: 6y 5m 7d Posted 25/09/18 01:54 PM Share Posted 25/09/18 01:54 PM HELP I have a XR6 2007 BF. I have added a turbo kit to it and also the XR6T ECU the new ECU is coming up with fault codes saying the Non Turbo PCM is not communicating with the turbo ECU. This is causing It to be stuck in limp mode and wont change out of 3rd gear 3rd gear goes surprisingly well. Iv Added turbo set up map sensor extra loom needed for boost and waist gate solarnoid. Both are BF 6 speed auto, I have heard you may be able to use a Ford au trans 4speed? Does anyone have any other ideas I have done a lot of work to it and I'm about to give up. Who's up for a challange Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 10m 10d Gender: Male Location: Canberra ACT Posted 25/09/18 08:50 PM Share Posted 25/09/18 08:50 PM Hey mate. Give us a bit more detail on exactly what you have done. A PCM and an ECU are two names for the same thing, so what you are saying doesn't quite make sense.What exactly did you swap into your car?What exactly are the fault codes?Lots of people have done swaps and conversions so might have seen similar issues. Link to comment Share on other sites More sharing options...
DRL07 New Member 3 Member For: 6y 5m 7d Posted 25/09/18 10:37 PM Author Share Posted 25/09/18 10:37 PM thanks for geting back to me so fast I have a non turbo bf vehicle, you have plus turbocharged it, fitted a 2bar map sensor, boost solenoid and boost pressure sensor. We are trying to program a turbo bf ECU(pcm) but are getting calibration fault codes and software incompatible codes from ABS and TRANSMISSION Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,280 Member For: 16y 10m 22d Gender: Male Location: Melbourne Posted 25/09/18 10:51 PM Share Posted 25/09/18 10:51 PM the PCM needs to be re-coded to suit the vehicle it's planted into, in terms of both being non-turbo originally and now turbo, plus being whatever transmission the PCM is out of and coded to your current transmission. Ford or somebody with solid understanding and toolset for these vehicles is required. Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 10m 10d Gender: Male Location: Canberra ACT Posted 26/09/18 01:15 AM Share Posted 26/09/18 01:15 AM What Keith said is spot on. You can't just plug and play the PCM but need someone to make it play nice. Link to comment Share on other sites More sharing options...
