  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 13d
I just leave it off, personally. Never had a problem as long as you tighten the manifold bolts/nuts often enough. :)
  • Dropping a turd
  • Member For: 17y 6m 26d
  On 21/09/2018 at 4:14 AM, pdidily6401 said:
yup, how critical is it to replace the "k" brace the sits between turbo and engine mount, seen a couple of comments where they have not put it back on.
Expand
Its there for a reason, but it back on....
  • 1 month later...
  • Member For: 6y 10m 14d
Ok new actuator fitted turbo smart 7.5 psi all good boost wise now not exceeding 8psi on gauge decided to give car a good run am now at bottom of South Island and what days know engine just cuts out while idling along it turns over good but won’t fire towed to garage no fault codes registered have ordered new fuel pump as mechanic thinks this is issue any advice
What days was whaddayaknow
  • Member For: 10y 3m 24d
  • Gender: Not Telling
Swap the fuel pump and let us know. I'm sure the mechanic would have listened to it priming or rather the lack of it priming so you should be sweet after this.
It should be pretty cheap too as the pump doesn't cost much and it doesn't take long to install.
Yup he has given me the run of the garage so going to pull pump tomorrow can hear it prime but no pressure in the line
 disconnected at pump and turned key could hear pump prime but no fuel pressure
  • Site Developer
Good job on getting it sorted... It's a reasonably common thing to occur when fuel pumps are installed.
