v1rus New Member 7 Member For: 6y 6m 14d Posted 09/09/18 08:39 PM Share Posted 09/09/18 08:39 PM (edited) hello hello, long story short stuffed my fuel line hose from the fuel pump assemble (has 460 in it) now one of the plugs pisses out when when pump starts up... the larger plug.. which one is that ? now, do I just run complete new aftermarket lines 98/E85 to the main rails under the car directly where ever these go to have to check, for both lines of the FG pump or just stick to the stock plug in type as they are now? this way seems messy and I dont think it will be an easy and quick fix. anyone know the part number of these lines and how much stuffing around I need to do?? had a quick look in the dark last night and seem I might need to drop tank removed shielded plates but cant locate the lines was to dark to see properly. cheers Edited 09/09/18 08:40 PM by v1rus Link to comment Share on other sites More sharing options...
v1rus New Member 7 Member For: 6y 6m 14d Posted 09/09/18 09:42 PM Author Share Posted 09/09/18 09:42 PM (edited) Will try call ford when they open or a wreckers.. but what do you guys think about going this route? anyone know sizes I need? PS: will definitely put on a clamp on also.. https://www.raceworks.com.au/fuel/e85-hose/push-lok-hose/ https://www.repco.com.au/en/brands/norma/connector-twin-pack/p/A5295182 http://www.autopartswholesalers.com.au/products/fuel-cooling-connectors/fuel-system-quick-connectors/fuel-system-quick-connectors-twin-packs/norma-fuel-system-quick-connector-twin-packs Edited 09/09/18 09:44 PM by v1rus Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 11m 10d Gender: Male Location: Perth Posted 10/09/18 06:49 AM Share Posted 10/09/18 06:49 AM Is it the fitting or the connection at the pump housing that is leaking? If fitting they will have O ring inside. Maybe you can just replace those from a replacement fitting you posted. You dont need new lines. Link to comment Share on other sites More sharing options...
