Garry H New Member 2 Member For: 6y 8m 22d Posted 09/09/18 09:44 AM Share Posted 09/09/18 09:44 AM Hi there, I have a 2011 FG XR6 and was told I needed to replace the rear upper control arm bushes either side. After doing a bit of research and pricing I found it was al lot cheaper and easier to replace the complete control arms with new bushes all round. I got stuck in and started replacing them I fitted the left side first and it was a breeze only took about 40minutes. But I’ve run into an issue with repacing right as I can’t seem to remove inner bush bolt, it’s like it’s been fitted the wrong way around or done so before shell of car was attached to chassis. Has anybody run into this problem before? Does this mean I am going have to unbolt and drop the whole back end to remove the bolt? I Can upload pictures in the morning. Cheers Garry Link to comment https://www.fordxr6turbo.com/forum/topic/94252-fg-rear-upper-control-arm-replacement/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,522 Member For: 17y 1m 21d Gender: Male Location: Melbourne Posted 09/09/18 10:02 AM Share Posted 09/09/18 10:02 AM I think this post has what you're looking for. Similar problem in the FG's as compared to the B-series, if I remember correctly. https://www.fordxr6turbo.com/forum/topic/90880-rear-camber-kits/?do=findComment&comment=1554827 Link to comment https://www.fordxr6turbo.com/forum/topic/94252-fg-rear-upper-control-arm-replacement/#findComment-1663772 Share on other sites More sharing options...
Garry H New Member 2 Member For: 6y 8m 22d Posted 09/09/18 01:01 PM Author Share Posted 09/09/18 01:01 PM Cheers man Looks like I have to drop the cradle to pull the bolt out, I’ll check the condition of other bushes while doing so theres no point doing the job twice. Thanks again. Link to comment https://www.fordxr6turbo.com/forum/topic/94252-fg-rear-upper-control-arm-replacement/#findComment-1663778 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,522 Member For: 17y 1m 21d Gender: Male Location: Melbourne Posted 09/09/18 01:03 PM Share Posted 09/09/18 01:03 PM no worries, mate. You only need to loosen some bits, like the posts a bit further down that thread say. also Link to comment https://www.fordxr6turbo.com/forum/topic/94252-fg-rear-upper-control-arm-replacement/#findComment-1663779 Share on other sites More sharing options...
