Mustangman570 Member 74 Member For: 11y 9m Posted 28/09/18 03:11 PM Author Share Posted 28/09/18 03:11 PM (edited) I haven't had much time to work on anything but homework and studying. But I was able to sneak away from all of that and start cleaning up the engine bay. I pulled out the engine wiring harness and and the harness for the lights. I will be doing a full wire tuck and weld up all the unnecessary holes while the engine is out. I will also be making new brake lines and converting to hydro boost for a cleaner look. Edited 28/09/18 03:12 PM by Mustangman570 3 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1664770 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 29/10/18 06:40 PM Author Share Posted 29/10/18 06:40 PM (edited) I finally had a little time to work on this beast. I am still waiting on my FG rear sump oil pan so I can't do much. Just more wiring harness removal, A/C lines removed and a good thorough cleaning. Don't worry, the A/C will be making a comeback in the future after some custom lines are made. Top is dirty bottom is cleanish. Edited 29/10/18 06:44 PM by Mustangman570 4 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666298 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 9m 27d Posted 30/10/18 12:33 AM Share Posted 30/10/18 12:33 AM Nicely done man, I have finally my head back from the machine shop. Recently de-burred the rough edges from the decking process, and then drilled and tapped the oil galley passages for plugs, and re-assembled. Cant wait to start prepping the engine bay for fab work, but im still a few months out, I think. Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666305 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 12/11/18 07:27 PM Author Share Posted 12/11/18 07:27 PM (edited) Rear sump FG oil pans finally got here. Out with the stock heavy k-member and in with the new sexy. There were some initial fitment issues. Edited 12/11/18 07:34 PM by Mustangman570 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666908 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 12/11/18 07:47 PM Author Share Posted 12/11/18 07:47 PM (edited) Here is a BA/BF front sump oil pan. You can see how much of a clearance issue there is with the front sump pan. I decided to try a different method. Instead of dealing with the whole motor I just bolted the oil pan to the transmission and used the stock transmission mount to locate the engine front to back. This made modifying the oil pan a LOT easier. Edited 12/11/18 07:49 PM by Mustangman570 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666909 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 12/11/18 08:01 PM Author Share Posted 12/11/18 08:01 PM (edited) I removed a "small" chunk from the BA/BF front sump oil pan. I also removed the front sway bar. Now it fits, even with the steering rack in place. IT FITS! The stock hood even closes (barely but that still counts). I am probably going to space the k-member down with 1 inch spacers. This should improve hood clearance, and help with my drive line angle a little. I'd like to see the motor "tilt" a little forward, nose down another 2 0r 3 degrees. 1 inch spacers are not going to give me any handling issues. I'll be able to adjust the suspension with back into spec. Adjustable coil overs, caster/camber plates, offset steering rack bushings and bump steer eliminators are common mods already really common. I have 3/4" spacers in my 5.4 4V 96 Cobra and it handles like its on rails. Edited 12/11/18 08:09 PM by Mustangman570 2 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666910 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 12/11/18 08:18 PM Author Share Posted 12/11/18 08:18 PM I know someone is going to ask why I modified a BA/BF front sump pan after going through the effort of getting a FG rear sump pan. I decided that I can modify the BA/BF pan without worrying about screwing it up since I have an extra. I have to notch the FG pan also. Doing it this way allows me to make the motor mounts and pin down the engine left/right and front/back. I'll modify the FG pan after the motor mounts are made. This way I cut it once and wont have to tweak it later if the motor mounts create an issue. I am probably being overly cautious but each oil pan costs me $300 USD after its shiped halfway across the world. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666911 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,573 Member For: 17y 2m 17d Gender: Male Location: Melbourne Posted 12/11/18 10:05 PM Share Posted 12/11/18 10:05 PM loving the updates, mate keep them coming. looking impressive in that engine bay; sitting high and proud 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666913 Share on other sites More sharing options...
Mustangman570 Member 74 Member For: 11y 9m Posted 12/11/18 10:55 PM Author Share Posted 12/11/18 10:55 PM Thanks bud. It's slow going with work, school and family spare time is almost non-existent. It helps build suspense I guess lol. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666915 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,573 Member For: 17y 2m 17d Gender: Male Location: Melbourne Posted 12/11/18 11:15 PM Share Posted 12/11/18 11:15 PM yeah; going slowly is fine with us 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94246-barra-swapping-a-1993-foxbody-mustang-in-the-united-states-of-america/page/6/#findComment-1666917 Share on other sites More sharing options...
