NA_TURBO Member 532 Member For: 9y 6m 29d Gender: Male Location: Mildura Posted 05/11/18 10:05 PM Share Posted 05/11/18 10:05 PM I've sent you a pm 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666630 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m 5d Posted 06/11/18 11:33 PM Author Share Posted 06/11/18 11:33 PM So today was a great day. Had some customers fall through, so had a bit of time today. Swapping the front sump girdle for a rear sump version. Re-torquing the main bolts. New rear main seal while im in there. And new rear mounted pick-up. Oil pan installed, and cross bolts with thread sealant. And finally!!!! The two together. ARP calls for 125ft. lbs, for the random bolts I had to order. Done and done. *Note to self, head bolts are not easily accessed with cams installed already, so small learning curve. Cams reinstalled. (Again) And started getting some timing ready to do, but enough for today. 6 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666689 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 10d Posted 07/11/18 08:11 AM Share Posted 07/11/18 08:11 AM Not really to late now, but if you look at the head stud washers they're not wide enough, maybe wonder off to a bolt place & see if you can find better fitting ones (Atomic sell them & I think they give the size on their website) 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666706 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,346 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 07/11/18 08:35 AM Share Posted 07/11/18 08:35 AM They're 28mm. Here is an ebay listing for them. If they wont post to Florida, I'll buy some and send them over if ya like. I don't see why you couldn't just use any other 28mm washer, providing it didn't lose tension on the head or deteriorate over time. https://www.ebay.com.au/itm/HP-XR6-Turbo-12mm-Head-Stud-Washers-28mm-OD-BA-FG-including-Territory-FPV/113254985941?hash=item1a5e85f0d5:g:ZzUAAOSwRbtaAEj0:rk:1:pf:0 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666708 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m 5d Posted 08/11/18 01:03 AM Author Share Posted 08/11/18 01:03 AM Ok ill have to take some measurements to tomorrow, and see what I can do about this. On 07/11/2018 at 8:11 AM, 4321 said: Not really to late now, but if you look at the head stud washers they're not wide enough, maybe wonder off to a bolt place & see if you can find better fitting ones (Atomic sell them & I think they give the size on their website) Expand OK so, my only issue with this is the ARP studs are not going to be long enough either now. After measuring out all of their requested numbers, this is the stud that would fit, and currently the nut runs down level with the top of the stud. Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666725 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,346 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 08/11/18 01:43 AM Share Posted 08/11/18 01:43 AM On 08/11/2018 at 1:03 AM, SelectivePC said: the ARP studs are not going to be long enough Expand You can put steel ball bearings in the block so the studs are raised up a bit. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666726 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m 5d Posted 08/11/18 02:06 AM Author Share Posted 08/11/18 02:06 AM Its stuff like this that makes me think you guys do the craziest stuff. I would have never of thought to do that, and I don't see why it wouldn't work. Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666728 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,346 Member For: 10y 3m 7d Gender: Male Location: South Australia Posted 08/11/18 02:39 AM Share Posted 08/11/18 02:39 AM 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666730 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m 5d Posted 08/11/18 03:33 AM Author Share Posted 08/11/18 03:33 AM So, just spent the last hour or two watching all of Atomic's videos, plus some other rabbit hole videos....looks like I have some work to do. :D Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1666736 Share on other sites More sharing options...
SelectivePC Member 79 Member For: 6y 8m 5d Posted 16/11/18 03:28 AM Author Share Posted 16/11/18 03:28 AM So learned how to use the plasma cutter today.....hmmm 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94245-barra-build-in-the-us/page/3/#findComment-1667043 Share on other sites More sharing options...
