  • Member For: 6y 9m 4d
Putting some king springs in my FG, SSL fronts and SSSL rears. Will it need a wheel alignment after they are swapped out? And if it does is it best to let the springs settle first before it's done?
A 4 wheel alignment was done a month ago when I got new tyres.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 15d
yeah, if it's heaps lower (which it will be with those springs), a bit of suspension geometry will need to be different, so a wheel alignment is a good idea. Definitely wait until it has settled.
  • Dropping a turd
  • Member For: 17y 6m 28d
100% need wheel align .  Dont drive to long after springs or will kill tyres... A few days to settle will be enough.
  • 2 weeks later...
Well I got the wheel alignment done, but they couldn't get enough adjustment and have recommeneded getting a camber kit for it. Something like 1.5 degrees on one side and 2.0 on the other? He said it will probably pull a little to the left, which it does. Nothing dramatic but a very slight drift to the left.
What are my options here. I have seen one kit on ebay for $50 each, and another for $115 each. Then there is the K mac kit which is expensive at $350. From what I can see it's just a new bracket and some shims. Might be a bit wary of the $50 one. No idea what the quality would be like on that.
I wasn't expecting it to need one as I reckon it has only come down 1 inch on the front. Although I haven't done an after measurement yet cause I want to let it settle some more.
Edited by G6EEEETTTT
  • Member For: 8y 23d
Yep, it won't be too much the shims come in different thickness as well. Just take it somewhere they won't overcharge you for doing it. I had quotes ranging from $175 to $50. The person I took mine to already had some shims laying around, ironically I had to take some out to get more -camber on the front. Just had another alignment this morning actually lol.
  • Dropping a turd
For good tyre life you want about 0.5 to 1.0 degree max. What they mean is they dont have enough thread for the thickness of shims to adjust.
