Conversion xr6t Member 61 Member For: 6y 10m 27d Gender: Male Location: Adelaide Posted 05/09/18 04:39 AM Share Posted 05/09/18 04:39 AM Hi I have a issue with my idle and even in Park the engine will stutter with no acceleration and also just as I accelerat. I have changed the fuel filter now I’m not sure where I should start I’m leaning towards either injectors coil packs or o2 sensor hopefully something simple but knowing my luck . Please let me know if your need any more info. Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 25d Gender: Male Location: Frankston, 3199 Posted 05/09/18 04:49 AM Share Posted 05/09/18 04:49 AM Have you got any way to read the ODB2 and check any codes? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 05/09/18 05:10 AM Share Posted 05/09/18 05:10 AM yeah, I'd be checking the o2 sensor first, as it's easy and cheap to fix. Then go with coils and spark plugs next. Also check if the catalytic converter has collapsed Link to comment Share on other sites More sharing options...
Conversion xr6t Member 61 Member For: 6y 10m 27d Gender: Male Location: Adelaide Posted 05/09/18 10:03 AM Author Share Posted 05/09/18 10:03 AM (edited) Awsome thanks k31th Ill do that I think cheers and had the cat block up on my merc and the car just went into limp mode would the cat made of made a noise like in the merc that sounded like a metal rattle for about a week before it blocked . And Rab some old dude come around to get some wood and he said I can youse his obd2 scanner while he loaded the wood and it came up with no codes that was last week Edited 05/09/18 10:04 AM by Conversion xr6t Link to comment Share on other sites More sharing options...
Conversion xr6t Member 61 Member For: 6y 10m 27d Gender: Male Location: Adelaide Posted 06/09/18 01:18 AM Author Share Posted 06/09/18 01:18 AM (edited) I haven’t started yet been making the cat a cubby house and reading others posts about similar issue anyway with my issue stated earlier I haven’t started yet but my fuel consumption is at around 3.2 litre p/h at idle normally sits around 1.2-1.6 would this help identify the problem closer and finally is the standard na o2 sensor the same as the turbo Edited 06/09/18 01:20 AM by Conversion xr6t Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 06/09/18 01:27 AM Share Posted 06/09/18 01:27 AM yeah, that does point towards a blocked cat or an o2 sensor problem. Either way, the car is getting the indication that there's more air in there than usual and is overfuelling to compensate and is running rich because there isn't actually any more air there. Yep, the o2 sensor is the same. 1 Link to comment Share on other sites More sharing options...
Conversion xr6t Member 61 Member For: 6y 10m 27d Gender: Male Location: Adelaide Posted 06/09/18 07:24 AM Author Share Posted 06/09/18 07:24 AM Awsome thankyou k31th I’ll change that in the morning and see how we go if not cut the cat and make straight through.is it true you can straight pipe turbos and they don’t damage valves n spring ect and and they don’t need back pressure because the turbo produces enuf Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 9d Gender: Male Location: Melbourne Posted 06/09/18 10:36 AM Share Posted 06/09/18 10:36 AM Nah, replace the cat, as it'll need a tune to suit the higher flow requirements without one or with a higher flow one. 1 Link to comment Share on other sites More sharing options...
Conversion xr6t Member 61 Member For: 6y 10m 27d Gender: Male Location: Adelaide Posted 08/09/18 08:19 AM Author Share Posted 08/09/18 08:19 AM well after all that it was plugs and coils. Turns out they were all original from factory except 2 coils. 145xxx km is that good or bad 1 Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 20d Gender: Male Location: WA, Perth Posted 19/09/18 03:26 AM Share Posted 19/09/18 03:26 AM thanks for taking the time and posting an update. At least now the next person knows where to start. Link to comment Share on other sites More sharing options...
