arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 29d Gender: Male Location: Perth Posted 01/09/18 06:08 AM Share Posted 01/09/18 06:08 AM (edited) I can see approx 8 mm of thread available at the end of each bolt. Just use bolts with ALL thread. It was obvious to me in post 1 what had happened, Just look at the offset of the pipe. Edited 01/09/18 06:10 AM by arronm Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 7y 6m 13d Posted 01/09/18 06:49 AM Author Share Posted 01/09/18 06:49 AM That’s a good idea with the all thread bolt. Didn’t realise til this morning that they didn’t thread all the way. Nice easy solution. Was kind of looking forward to doing my first tap! Anyhoo have picked up a bit of knowledge for when I need to do it down the track. Cheers. You reckon a hose join is a good idea or just use the part I ordered? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,161 Member For: 16y 9m 15d Gender: Male Location: Melbourne Posted 01/09/18 07:03 AM Share Posted 01/09/18 07:03 AM Use the part you ordered. 1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 29d Gender: Male Location: Perth Posted 01/09/18 07:03 AM Share Posted 01/09/18 07:03 AM How much is the part? Is it a blind hole. Looks like 8 mm, if blind hole , run a 8 mm bottoming tap down to make sure the threads are tapped all the way. Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 7y 6m 13d Posted 01/09/18 07:35 AM Author Share Posted 01/09/18 07:35 AM I think around $100 from memory. It’s ok it’s on its way already so prob just use it. Yeah its 8mm hole. Haven’t stuck any wire in yet will do tomorrow as spent most of day just cleaning off all the underbody and removing the split line and doing diff oil tightening manifold bolts etc. the fact that the bolt would do up tightly without the metal gasket in there is interesting. Correct me if im wrong but if the damage to the thread hole is right near the bottom then wouldn’t a shorter bolt be what I need? Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 29d Gender: Male Location: Perth Posted 01/09/18 07:52 AM Share Posted 01/09/18 07:52 AM (edited) 21 minutes ago, joffa1 said: the fact that the bolt would do up tightly without the metal gasket in there is interesting. Correct me if im wrong but if the damage to the thread hole is right near the bottom then wouldn’t a shorter bolt be what I need? @$100 just install the new part Think about your statement carefully. It tightens up when the bolt is engaged further into the thread, SO..... OR measure, is the bolt bottoming?, Come on dude sort it out, its not rocket science. I have given you all the information you need to sort the problem .. Edited 01/09/18 07:57 AM by arronm Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 7y 6m 13d Posted 01/09/18 07:57 AM Author Share Posted 01/09/18 07:57 AM (edited) Yeah I guess it’s the opposite, my thinking is that the damaged part of thread hole is right at the end so if the newer shorter bolt tightens up the component before it gets to the damaged part eureka. Anyway Could be wrong but I’ll get there. Thanks for the advice I appreciate it and sense some narkiness coming on so I’ll stop! cheers mate Edited 01/09/18 07:58 AM by joffa1 Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 2m 29d Gender: Male Location: Perth Posted 01/09/18 08:00 AM Share Posted 01/09/18 08:00 AM Sorry if I come across harsh, but its been 3 pages for a simple issue. I have given solid advice. Follow it and you will sort it easy. 1 Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 7y 6m 13d Posted 01/09/18 08:07 AM Author Share Posted 01/09/18 08:07 AM All good mate thanks Link to comment Share on other sites More sharing options...
joffa1 Member 143 Member For: 7y 6m 13d Posted 02/09/18 03:19 AM Author Share Posted 02/09/18 03:19 AM For benefit of those interested it’s a 20mm blind hole and I will take advice given and try a m8 20mm bolt threaded all the way. Link to comment Share on other sites More sharing options...
