Renton Member 151 Member For: 7y 1m 24d Gender: Male Location: Perth Posted 27/08/18 11:29 PM Share Posted 27/08/18 11:29 PM I'm not familiar with the thread repair stuff. Is it like a quickmetal putty or epoxy? If so you'd still have to be careful not to get any in the sump. Yes you could use some sort of rtv silicone as a temp fix. Make sure you clean all oil off flanges and the bolt with brake cleaner or metho. Put a bit on the face of the flange and about 5 to 10mm of the bolt shaft/thread near the head of bolt, and I'd let it set for 24 hrs before driving. As I said I think it will be a temp fix so it may still drip but at least you'll slow it down. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663028 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 18d Posted 28/08/18 05:55 AM Author Share Posted 28/08/18 05:55 AM Definitely a temp fix but will at least let me drive a few clicks to get all the parts I need. Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663053 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 18d Posted 29/08/18 11:00 PM Author Share Posted 29/08/18 11:00 PM Temp fix helped but didn’t stop the flow. Just grabbing a new oil return line from Ford now. Will I I be able to remove and install new one up at the turbo end easily enough? How is access? I’m assuming it’s not a turbo out job... any other tips... I assume new gaskets too? Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663149 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,522 Member For: 17y 1m 20d Gender: Male Location: Melbourne Posted 29/08/18 11:14 PM Share Posted 29/08/18 11:14 PM Yeah, it's do-able from underneath, but it's tricky to get a socket in the turbo end to tighten it. Definitely get new gaskets. Otherwise, just torque to a fairly soft specification. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663150 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 18d Posted 30/08/18 01:39 AM Author Share Posted 30/08/18 01:39 AM So Knox Ford have just told me they don’t make the part anymore... saying it’s obsolete. Seems odd 2012 model. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663155 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 30/08/18 01:45 AM Share Posted 30/08/18 01:45 AM This might help. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F182741660572 Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663156 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 18d Posted 30/08/18 02:10 AM Author Share Posted 30/08/18 02:10 AM Have seen this. Think it’s my only option now. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663158 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 1d Gender: Not Telling Posted 30/08/18 02:15 AM Share Posted 30/08/18 02:15 AM Ha I just scrolled to the start of the thread and saw you already linked it. Oh well. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663159 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 18d Posted 30/08/18 02:20 AM Author Share Posted 30/08/18 02:20 AM All good mate thanks for the help Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663160 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 2m 4d Posted 30/08/18 07:21 AM Share Posted 30/08/18 07:21 AM The threads into the sump are blind, so you only have to block the return hole. With your fresh oil just drain it into a clean container & put it back in when your finished. The helicoil can be bought as a kit with the right drill bit. You can even buy a right angle adaptor for your drill if it's to long to fit in. Measure the depth of the hole & transfer this measurement to your drill bit with some masking tape- do not drill through! plan B is ring a mobile thread repair bloke & get out of his way! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/2/#findComment-1663183 Share on other sites More sharing options...
