arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 6d Gender: Male Location: Perth Posted 02/09/18 03:58 AM Share Posted 02/09/18 03:58 AM (edited) So 20mm + thickness of pipe connector plate and that's the length of bolt to use. I suggest replacing both. If you have bottoming tap , run it down to clean up the threads. Seeing as its blind , spray out with a cleaning fluid to flush the hole. If you dont have a new gasket , clean the old one and use a quality silicone gasket material on both sides. Use 243 loctite on the bolts and just nip them up. They dont need to be very tight. Manual says 20Nm , but with gasket material the joint will hold its self so 15 would be enough. You dont want to destroy the threads that are left. Additionally the one hole that is good can go tighter and that will better hold the joint. One last thing. Offer up the pipe to the turbo and sump. It should fit perfect and not be a stretch. If it is you need to rotate the turbo core. If this is the case, this is likely why it failed. BUT sometimes the cores after time wont rotate easily. If that's the case return the new line and use a piece of HIGH temp rubber hose and join the two. Good luck. Should be sweet Edited 02/09/18 04:11 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663364 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 21d Posted 02/09/18 07:07 AM Author Share Posted 02/09/18 07:07 AM Awesome mate thanks for the run through very helpful. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663380 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 21d Posted 02/09/18 07:17 AM Author Share Posted 02/09/18 07:17 AM Was also going to ask while I’ve got a few components removed and decent access around the turbo is there any other things I can look out for/maintenance I can do? I’ve got use of another car for a week so thought I might do some other bits and pieces while it’s up on stands. Fyi 2012 fg xr6t manual with just shy of 100,000. I’ve done gearbox oil, diff oil, engine oil and filter, tightened up manifold bolts. Was thinking wd40 on the boost solenoid... anything else jump out... cleaning of throttle body, intake components maybe? Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663381 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,526 Member For: 17y 1m 23d Gender: Male Location: Melbourne Posted 02/09/18 07:54 AM Share Posted 02/09/18 07:54 AM High pressure power steering hose is in that area, too. Change all of the gaskets for anything you remove, change bolts out for replacements where necessary, look for leaks and residue, clean the engine earth strap, check the exhaust for cracks, check the steering linkages and suspension linkages etc. Plenty you can do while you're down there. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663382 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 21d Posted 02/09/18 09:03 AM Author Share Posted 02/09/18 09:03 AM Ok great... could you go into a little more info regarding linkages? What to look for where etc? Thanks again. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663384 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,526 Member For: 17y 1m 23d Gender: Male Location: Melbourne Posted 02/09/18 09:35 AM Share Posted 02/09/18 09:35 AM Just where bits of metal join to one another etc. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663386 Share on other sites More sharing options...
joffa1 Member 162 Member For: 7y 10m 21d Posted 02/09/18 10:47 AM Author Share Posted 02/09/18 10:47 AM Ok cheers Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1663393 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 1m 1d Gender: Male Location: Brisbane Posted 27/10/21 10:25 AM Share Posted 27/10/21 10:25 AM Does anyone know the size of the oil return hole on the block, the ford return pipe is 13mm. Is it the same, anyone have an engine out or a block sitting around or know. Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1708794 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 4d Gender: Not Telling Posted 02/11/21 07:40 AM Share Posted 02/11/21 07:40 AM Somewhere around 17.6mm to 17.75mm. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94222-oil-return-line-leak/page/7/#findComment-1708892 Share on other sites More sharing options...
