jdracing New Member 18 Member For: 6y 6m 4d Posted 27/08/18 04:26 AM Share Posted 27/08/18 04:26 AM Hi I have a BF Falcon and I got another new remote and as I did previously last time I had to train the remote I took the same steps. close the door turn key to ACC then press rear demister 3 times within 5 seconds and the doors will cycle then press a button on first remote and so on, trouble is this time nothing happened when I pressed my remotes it did not train them and when I try to do the process of pressing the rear demister 3 times nothing happens so I cant train any of them as nothing happens when I press the demister 3 times it doesn't do the door cycle like it should. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 27/08/18 04:30 AM Share Posted 27/08/18 04:30 AM You need two working remotes to do it the way you're describing. Link to comment Share on other sites More sharing options...
jdracing New Member 18 Member For: 6y 6m 4d Posted 27/08/18 04:31 AM Author Share Posted 27/08/18 04:31 AM I had 2 working remotes, but as I said it wont even do the locking sequence when I press the demister 3 times, so it's no longer doing anything. Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 20d Gender: Male Location: WA, Perth Posted 27/08/18 04:33 AM Share Posted 27/08/18 04:33 AM so how else can this be done, if you don't have two remotes? I think that a licensed version of Forscan is required, is it not? Link to comment Share on other sites More sharing options...
jdracing New Member 18 Member For: 6y 6m 4d Posted 27/08/18 04:35 AM Author Share Posted 27/08/18 04:35 AM I have 3 remotes 2 already matched I am not talking about coding a key it is training the remote Link to comment Share on other sites More sharing options...
jdracing New Member 18 Member For: 6y 6m 4d Posted 27/08/18 05:54 AM Author Share Posted 27/08/18 05:54 AM All sorted Link to comment Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 2m 20d Gender: Male Location: WA, Perth Posted 27/08/18 06:01 AM Share Posted 27/08/18 06:01 AM how did you fix it? come on share it with the rest. Link to comment Share on other sites More sharing options...
jdracing New Member 18 Member For: 6y 6m 4d Posted 27/08/18 01:21 PM Author Share Posted 27/08/18 01:21 PM Disconnect the car battery for 30 minutes, reconnect then turned the key to acc and press the rear demister button 3 times within 5 seconds of turning the key and the doors locked ( wow I fixed it ) then I pressed a button on remote 1 and the doors locked / unlocked and repeated for the next 2 then turned the key off all set. So basically to get the rear demister to function for this purpose again I just had to disconnect the battery for 30 minutes, this reset the system and allowed it to function as per normal again. Your welcome I have 2 problems with the car and wonder if anyone has the fix ? XR BF Falcon 06 1/ Headlights don't come on when set to Auto ? 2/ Boot light/luggage compartment light not working, globe is ok, fuse is ok and if the metal on the globe holder touches the metal om the car it sparks, so I can assume it has power lol ? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 27/08/18 01:27 PM Share Posted 27/08/18 01:27 PM 1/ Probably the switch is defective. 2/ Good chance that the wires are just loose on the connector and the movement of the boot causes it to dislodge. 1 Link to comment Share on other sites More sharing options...
jdracing New Member 18 Member For: 6y 6m 4d Posted 28/08/18 11:40 AM Author Share Posted 28/08/18 11:40 AM I will try again as my previous post vanished I have 2 problems with the car and wonder if anyone has the fix ? XR BF Falcon 06 Link to comment Share on other sites More sharing options...
