Baxr6typhoon89 New Member 3 Member For: 6y 9m 3d Posted 20/08/18 09:16 AM Share Posted 20/08/18 09:16 AM (edited) I've just purchased a completely stock 04 ba xr6 n/a I have a worked bf f6 motor apparently to about 450 rwhp with all the loom ECu etc, just looking for advice reccomendations and possible problems I might encounter with my conversion Edited 20/08/18 09:18 AM by Baxr6typhoon89 More info Link to comment https://www.fordxr6turbo.com/forum/topic/94201-ba-xr6-na-to-worked-bf-f6-typhoon/ Share on other sites More sharing options...
skotty Member 52 Member For: 11y 4m 9d Posted 21/08/18 05:59 AM Share Posted 21/08/18 05:59 AM To use the BF PCM there will need to be a loom swap for starters, and possible ABS module replacement, which ill mean a AC regas as you gotta swap a AC line to swap the module.. Is it a auto or manual PCM /ECU you got? Link to comment https://www.fordxr6turbo.com/forum/topic/94201-ba-xr6-na-to-worked-bf-f6-typhoon/#findComment-1662457 Share on other sites More sharing options...
Baxr6typhoon89 New Member 3 Member For: 6y 9m 3d Posted 21/08/18 03:16 PM Author Share Posted 21/08/18 03:16 PM It is out of an auto. Link to comment https://www.fordxr6turbo.com/forum/topic/94201-ba-xr6-na-to-worked-bf-f6-typhoon/#findComment-1662510 Share on other sites More sharing options...
tazzanz Donating Members 573 Member For: 9y 9m 22d Gender: Male Location: NZ Posted 21/08/18 03:38 PM Share Posted 21/08/18 03:38 PM up the sharkies 1 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94201-ba-xr6-na-to-worked-bf-f6-typhoon/#findComment-1662511 Share on other sites More sharing options...
