BigKriss Member 42 Member For: 13y 5m 22d Gender: Male Location: Sydney, Australia Posted 19/08/18 11:09 AM Share Posted 19/08/18 11:09 AM Changing my 4 brembo rotors (Brembo rotors and pads) at the.moment for DBA 4000 slotted rotors and ferodo ds performance pads. I'm stuck at taking the rotor off. I put some WD40 on the studs. do I have to do anything with the handbrake pretensioner? Can I just wack the rotor off with a larger 3lb hammer? Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,508 Member For: 17y 1m 11d Gender: Male Location: Melbourne Posted 19/08/18 11:15 AM Share Posted 19/08/18 11:15 AM it'll be rusted on.... not unusual for the rear to be a PITA get get off. Either a big gear puller or a lot of hard work with a hammer to work it loose. Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662331 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 19d Gender: Male Location: Western Sydney Posted 19/08/18 11:20 AM Share Posted 19/08/18 11:20 AM Make sure the handbrake is off aswell. Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662332 Share on other sites More sharing options...
BigKriss Member 42 Member For: 13y 5m 22d Gender: Male Location: Sydney, Australia Posted 19/08/18 11:36 AM Author Share Posted 19/08/18 11:36 AM Thanks guys Yes handbrake is off I'm slowly working it off. It seems to be tighter around the adjuster bolt. I tried to loosen it but nothing happened. Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662333 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 24d Gender: Male Location: Perth Posted 19/08/18 03:00 PM Share Posted 19/08/18 03:00 PM You can loosen at the bolt at the tunnel. Only hit with a soft blow hammer. And turn either clockwise or anticlockwise as you pull them off. One of those directions will come off easier. Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662339 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 24d Posted 19/08/18 07:55 PM Share Posted 19/08/18 07:55 PM Sounds like you have to back the hand brake adjustment off. (if its moving you broken the rust 'seal') It's the toothed wheel at around 2 or4 oçlock through the hole between the wheel studs Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662340 Share on other sites More sharing options...
BigKriss Member 42 Member For: 13y 5m 22d Gender: Male Location: Sydney, Australia Posted 20/08/18 12:27 AM Author Share Posted 20/08/18 12:27 AM Hi mate It feels as if when I'm taking the rotor off the hand brake lining wants to come with it I can't find the adjuster you are mentioning I can find two of these, I think we are talking about different things I could put a video up to show everyone On 19/08/2018 at 11:15 AM, k31th said: it'll be rusted on.... not unusual for the rear to be a PITA get get off. Either a big gear puller or a lot of hard work with a hammer to work it loose. Expand I've got a big gear puller, are you sure this is ok? Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662346 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,508 Member For: 17y 1m 11d Gender: Male Location: Melbourne Posted 20/08/18 12:39 AM Share Posted 20/08/18 12:39 AM yep, ideally it'd be a 4 jaw puller, but that'd do the job if it's not slipping as you tighten it. Assuming you're not re-using the brake disc, it's fine to damage it in pulling it off. Just a warning, there'll be a loud sound as you pull it off, using this method (I've done it a few times haha). Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662348 Share on other sites More sharing options...
BigKriss Member 42 Member For: 13y 5m 22d Gender: Male Location: Sydney, Australia Posted 20/08/18 12:44 AM Author Share Posted 20/08/18 12:44 AM Ok mate thanks for the quick replyI've got new rotors to replace themIt feels I'm going to break something when I pull it off Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662349 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 21d Gender: Not Telling Posted 20/08/18 01:02 AM Share Posted 20/08/18 01:02 AM Use an axle stand mate. It might save your life. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94196-changing-rear-brembo-rotors/#findComment-1662350 Share on other sites More sharing options...
