Cam upgrade
Callum1998
  • Member For: 7y 7m 18d
The stock cams are just a little small I reckon, something with a 6500 redline would of been nice with good mid range. If you do the cams get the head a mild port as well. Good gains then with a small cam upgrade. Headsense in Brisbane have got good results with this.
  • Member For: 7y 8d
Yeah that’s what I’ve read else where as well, but what would I spend my money on? I would like to make 500kw at the rears. I want something a little different, everyone that mods a xr t bolts on a bigger turbo and goes ethanol, another reason wanted cans don’t see many around with them
@OZYWALKER
do you still run standard converter?
Is the car a bit harder to cruise around and what is the idle like? Would you recommend them after your own experience with them
  • Puff
  • Member For: 9y 10m 20d
My logs show the stock cams falling over at about 5000rpm. I have taken it to 6700rpm in first and second but in the higher gears there is no point revving past 5500rpm on stock cams.
  • Dropping a turd
  • Member For: 17y 1m 22d
Puff.  There is a lot more to it than that.   Stock cams can still make power up to 7k.  You just need the knowledgeable tuner.
  • Puff
No.
Edit: Lol sorry, that was a low effort post. I know there is a lot more to it but you can only explain so much on a forum post without writing a novel. I'll settle for a maybe as there are plenty of variables.
Edited by Puffwagon
