  • Dropping a turd
  • Member For: 17y 7m 25d
  • 4 months later...
  • Member For: 9y 8m 12d
Stock fuel pressure regulator probably won't be able to hold back the pressure.
You'll need an aftermarket reg and possibly fuel rail. GFB do a direct replacement reg, turbosmart do an adaptor fitting to run an external reg.
  • 3 months later...
  • Member For: 7y 1m 12d
Can confirm a Walbro 460 delivers to much fuel for the stock reg to handle, mine was sitting at around 75 psi fuel pressure at idle when it should have been a tad under 60.
have heard some people drill out the return on the stock regulator, this requires precision as if you hit the wrong thing u will need a replacement reg. the return patch through the stock regulator is something like 2MM its a baby for high volume pumps.
plenty of company's make fittings/bolt in regulators if you want to just take that path.
