Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 8d Gender: Male Location: South Australia Posted 31/07/18 12:36 PM Share Posted 31/07/18 12:36 PM @camo86T and @OZYWALKER have high powered utes. @Ford Freak might still have one too All of these guys can talk from experience. An open diff won't deliver power evenly though so that could be what's going on. Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 25d Gender: Male Location: SW Sydney Posted 31/07/18 08:50 PM Share Posted 31/07/18 08:50 PM @Brad3199 when you say "in a straight line" I presume you're not dumping the clutch....and that you've driven manual for a while The last time I had an experience like you're describing was probably about 12 years ago, used to happen regularly in the work ute, but that was a trayback 2.7L hilux with sh*tty 185s all round. Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 24d Gender: Male Location: Perth Posted 31/07/18 09:46 PM Share Posted 31/07/18 09:46 PM Reminds me of my old FG XR6T in the wet - roll-on in pretty much any gear and as soon as it got a whiff of boost the back end jumped out. Good times But yes, sounds like it's the tyres. Link to comment Share on other sites More sharing options...
hopper8 Member 47 Member For: 7y 4d Posted 01/08/18 12:36 AM Share Posted 01/08/18 12:36 AM I've often wondered the same thing. My FG XR6T sedan does the same thing, and it's running near new Goodyear Eagle F1 Directionals - not some dodgy rubbish. When the rear breaks traction it'll snap sideways occasionally. Very, very unpredictable and lightning quick to go. I thought it was normal for LSD... It's not?? Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 11m 24d Gender: Male Location: Perth Posted 01/08/18 12:54 AM Share Posted 01/08/18 12:54 AM To be honest, probably more a reflection of the chassis and overall handling dynamics of the vehicle, than LSD and tyres alone. My Bogan special-R didn't even remotely behave like that - was very much more planted and well behaved. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 8d Gender: Male Location: South Australia Posted 01/08/18 12:57 AM Share Posted 01/08/18 12:57 AM I only use cheap semis cos nothing lasts longer than 3 months and although the car wants to keep going around when you are doing donuts, it goes straight when you powerskid. At the local track I've had it skidding and sideways but going straight at 140kph with no issues apart from a puckered butt hole. @k31th asked me how I keep it straight when we went on the cruise and I thought it was an odd question cos you just floor it and steer with a gentle correction every now and then. It's gotta be a front or rear alignment thing that is causing some cars with lsd's to try and kill ya. I have stiffer blade and diff bushes so that might be a factor? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 01/08/18 01:01 AM Share Posted 01/08/18 01:01 AM haha, that question was asked to specifically find out how your own steering corrections are input, if you do anything normally. For me, with powerful falcons with a decent rear-end stiffness setup (just better bushes), going straight is perfectly normal on straight roads with good quality tyres and when they do let go, it doesn't kick. I find they kick when you've got slight lock on the steering wheel and it'll predictably kick out with the centripetal force direction based on the steering angle (or if hte road has obvious camber, it'll kick out on gravity assist from the road camber). Link to comment Share on other sites More sharing options...
hopper8 Member 47 Member For: 7y 4d Posted 01/08/18 01:02 AM Share Posted 01/08/18 01:02 AM Is this with TC off I assume?? I generally drive with TC on and only turn it off when I "know" I'll need it off. Maybe TC cuts in weirdly on one wheel and the 'free' wheel flicks the car?? Mine is a manual so no powerskids. I recently had a wheel alignment done too... Edit: Keith's reply above.. Maybe it's road camber that's killing me actually, come to think of it. My rear end is tight and running Nolathane bushes (put in by previous owner) Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,294 Member For: 16y 10m 27d Gender: Male Location: Melbourne Posted 01/08/18 01:04 AM Share Posted 01/08/18 01:04 AM TC is unpredictable... so I wouldn't rely on it to help other than in scenario's that you really don't want to be out of control and you can simultaneously let go of the steering (or at least no further inputs) and push the brake if necessary (but at least let go of the throttle) and it'll then cut power at the same time you do and that'll probably correct most basic kick situations quickly enough to a state where you can go onwards again. Yes, if you want to do "spirited driving", of course turn the TC off, but TC stays on otherwise. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 8d Gender: Male Location: South Australia Posted 01/08/18 01:15 AM Share Posted 01/08/18 01:15 AM I don't bother with tc as it is more predictable when it's off. After a couple of WOT pulls it switches off by itself anyway. You get some pretty good choo choos when it's on in the wet. 11 minutes ago, k31th said: how your own steering corrections are input, if you do anything normally. I don't have any magic formula to not losing it. Some cars are easier than others to keep straight. 1 Link to comment Share on other sites More sharing options...
