  • Member For: 6y 8m 17d
Hi guys, new here. I'm doing a FG long block into BA conversion also a t5 to t56. The engine harness is for a ZF 6 speed auto, but my BA ECU is tuned for a t5 manual. Will it be okay to run with the automatic connections taped up? Or will the Canbus wiring cause trouble?
  • Puff
  • Member For: 10y 2m 14d
From what I understand you will need to switch the trans over in the pcm but I haven't tried it myself. I think you need to do something about the reverse switch too to prevent issues but you'd need to double check on that.
There are a few dudes on here that will be able to chime in with a bit more detail. There is a fair bit of conversion info on the hp tuners site.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 3d
talk about a convoluted way to get it working... I doubt that a ZF loom will work with a T56 or a BA ECU. Best to get matching hardware, where possible.
  • Puff
Oopsie when he said engine harness I assumed there would be an pcm with it.
I know but apprentice wages :33
Spoke to a whole bunch of people yesterday, the only thing I have to worry about is the inhibitor switch and reverse lockout. Going to run the lockout off a relay and break switch. Do you guys know where abouts the connector is for the inhibitor switch, the one the other side of the ECU?
