Z2TT Member 714 Member For: 13y 13d Posted 21/07/18 04:01 PM Share Posted 21/07/18 04:01 PM (edited) Hi Guys.I just got a BA wagon and 1st gear really doesn't seem to be anything great. Before I had a VT Late model camira which was very peppy in 1st gear. it's a petrol carI know the falcon has a much shorter 1st gear but heaps more torque. A friends BA Auto ute would fly off the starting lineI've seen other threads on different forums with some people asking the same thing.I've seen AU Auto's jump off the line quickly.Some guys mentioned the cable throttle holds back the car in 1st gear to make it more streetable hence giving the lag like feeling.Is there any versions of the 4 Speed box that have a better 1st gear ratio I could swap in from any other BA or possibly AU?Not looking into an option to just go a shorter diff as I only want to make 1st gear shorter.The only other option is a ZF swap which is very expensive as wagons never had the 6 speedCheers Edited 21/07/18 04:10 PM by Z2TT Link to comment https://www.fordxr6turbo.com/forum/topic/94112-ba-sluggish-down-low/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,538 Member For: 17y 1m 30d Gender: Male Location: Melbourne Posted 22/07/18 12:21 AM Share Posted 22/07/18 12:21 AM Yeah, you'll be looking for a gearbox change, as making a gear smaller but still engage properly won't be a cheap exercise on your current gearbox, but of course with money and time, anything is possible It's pretty normal to feel slow off the line in a BA, especially if you compare directly to the equivalent model of bogan special. Link to comment https://www.fordxr6turbo.com/forum/topic/94112-ba-sluggish-down-low/#findComment-1660606 Share on other sites More sharing options...
Z2TT Member 714 Member For: 13y 13d Posted 22/07/18 04:00 PM Author Share Posted 22/07/18 04:00 PM (edited) Fair enough. I'm not sure if there's a shorter 1st gear ratio I can put inside from another BTR box that can fit in the BTR box of the BA otherwise the only real solution is a ZF conversion. Cannot I retrofit a AU mechanicals and re-use BA electronics? Edited 22/07/18 04:01 PM by Z2TT 1 Link to comment https://www.fordxr6turbo.com/forum/topic/94112-ba-sluggish-down-low/#findComment-1660633 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,538 Member For: 17y 1m 30d Gender: Male Location: Melbourne Posted 23/07/18 12:18 AM Share Posted 23/07/18 12:18 AM no idea on that specific front. Probably best to speak to a gearbox specialist on that one. Link to comment https://www.fordxr6turbo.com/forum/topic/94112-ba-sluggish-down-low/#findComment-1660637 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 5m 12d Gender: Not Telling Posted 29/11/18 11:32 PM Share Posted 29/11/18 11:32 PM On 22/07/2018 at 4:00 PM, Z2TT said: the only real solution is a ZF conversion. Expand thread mine but cmon fit a turbo barra + zf.... you know you want to. Link to comment https://www.fordxr6turbo.com/forum/topic/94112-ba-sluggish-down-low/#findComment-1667600 Share on other sites More sharing options...
