  • Member For: 11y 7m 16d
Yes they are.
I had 7 of them imported. I plan on keeping 2 and selling the other 5. My last resort is to pull the head off and check the pistons, I was hoping for an external indicator. Is there a way of telling from the bottom? I have heard the turbo motor has piston oil squirters, can anyone confirm this? I would rather pull the oil pan than the head.
I'm mainly trying to decide which 2 motors to keep. If this turns out to be a turbo motor I can sell for a little more. Use that profit to purchase better rods and pistons for the 2 motors I am keeping.
  • Dropping a turd
  • Member For: 17y 6m 16d
Post an image of the location the turbo oil filter will be.
Those exhaust manifold bolts are not the correct ones.
That motor appears to be a turbo engine. The N/A exhaust manifold may have been installed for transport.
Edited by arronm
  • Dropping a turd
Not really , but yes. You can see the turbo filter has been removed ( hole in block). That is where the oil pressure comes from (has sensor). The sensor in front of that is oil temp. The sensor above is knock sensor. If it has another one at the rear of the engine its BF if only one its a BA.
My opinion it is a turbo motor. If it didnt have a turbo oil line , the oil pressure sensor would be still in the block..
Also note the black/white one way valve in the PCV valve hose. Only turbo has that..
Edited by arronm
  • Bronze Donating Members
  • Member For: 11y 1m 17d
I reckon that aaron is right, only the turbo has a oil temp switch (and the wiring to plug into it) If you were to run it oil would come out the drain back hole so to me , like arron said, the na exhaust was put on for handling purpose's. The inlet manifold has no broadband stuff which is also turbo only
  • FREAKY
  • Member For: 15y 4m 18d
interesting
surprised your not playing with the new mustang like all the others with its dodgy new 10 speed hahaha
I would lo e to get my hands on that new 10 speed. That transmission is amazing. I'm putting one of these motors in my Foxbody Mustang, one in my brothers Jeep Wrangler and one in my F150.
