  • New Member
  • Member For: 6y 10m 22d
Hey just getting into the turbo  game, just bought a xr6t tonner but was very sluggish.tested waste gate actuator and could blow through it.
Replaced with a new turbo smart 7/14 psi but it wont open the flapper. My main question is the pressure hose from the front of the turbo when running
has no pressure or vacuum should it have something? I put hose on and could blow air and inhale with ease, should this happen??
https://www.fordxr6turbo.com/forum/topic/94040-boost-at-14-at-idle/
  • Member For: 17y 5m 24d
Its quite confusing what you have said
But the hose from the compressor should goto a small solenoid and then another hose from solenoid to wastegate
Also replacing the wastegate with a higher pressure than standard is a bad idea as you will now over boost
Good chance of your motor going boom if your not careful
  • New Member
Hey Wilko thanks for input the hose from the compressor doesn't seem to build pressure to open the actuator it is hooked up exactly as you said,
but pulled hose from compressor to see if there was any pressure nothing
  • Member For: 20y 7m 22d
Possibly the boost reference nipple is blocked. Is there any reminisce of oil in the compressor housing?
If so the nipple it self could be clogged up?
If you disconnect the hose can you blow through it?
Weird!
  • New Member
weird yep the boost nipple on the  front of the compressor, yes can blow and suck with no resistance there is a very slight sign of oil in the entrance to compressor
but nothing to be concerning
How are you measuring that it doesnt build up pressure ?
As I said earlier, driving with that hose off or blocked can be very bad
  • New Member
ok just removed turbo and reset the preload on the wastegate actuator better but still feels like theres no turbo, can anyone refer a good dyno tuner on the gold coast I need to get sorted asap as it is a work car, any help would be awesome.
Hi wilko I removed the hose from the electronic boost gauge and held my finger over it then I spat on the end while running and there was nothing
  • Bronze Donating Members
  • Member For: 11y 1m 18d
As the turbo builds boost ( which it shouldn't at idle) the pressure goes down the hose to the actuator, which is about 7 psi standard, when the actuator see's 7 psi it should move the actuator which opens the flap allowing the exhaust gas's to  bypass the exhaust wheel which should stop the compressor wheel from making more boost. The turbo needs a fair amount of exhaust flow to make it work, you won't get this at idle & probably  not even at light cruise but when you start to accelerate you should start to see boost. Stick a boost guage on & take it for a drive & if it goes over 7psi back of the accelerator & drive it like a busted slug to your tuner!
  • 1 month later...
  • New Member
Update took car to hi torque in arundel they said the actuator arm was hitting the heat shield and had no time to fix it. I bought it home removed hose from boost valve and hooked it up directly to a foot pump, actuator arm moved freely hi torque talking sh*t. Alas still have the bloody problem. will know book it into P.I.T at molendinar once I change the springs to 7psi as I fitted a 14psi oops.
