Help! Re-Attach G6ET Boot Lip???
MaStars
  • Member For: 7y 5m 23d
Hi fellow boosted ford folk.
So I have noticed factory boot lip on my G6ET is lifting at the far edges, to the point now I think it might rip off on my next highway trip.
I was wondering if anyone has had this and how they rectified it? my main questions are as such;
  1. what is the best way to remove it so I can re attached. I was thinking some fishing line back and forward between the tape and the boot? but I'm sure there might be a better way.
  2. Is it held on by any screws? or is it the double sided looking tape/silicon stuff I can see under there it?
  3. What is the material that is holding it down? it looks like either double sided tape or even a silicon type adhesive, I want to be sure I buy the correct stuff to re-attach.
  4. Is there some sort of better material to hold it down to stop it lifting again? anyone had success with a particular product?
any help would be very appreciated, thanks in advance :)
Ben
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 7m 17d
I've heard about it being sikaflex or something similar... that's all I know :) surely somebody else has experienced it and can comment.
  • Member For: 6y 8m 24d
Hey mate just getting back to you in regards to your spoiler. Took my car to panel shop today and it turns out that mine had sikaflex added at a later date, not like that from factory. The panelbeater has done a few and he rekons just spray under and around your spoiler where u can see the double sided adhesive, with an orange agent type of gunk and adhesive remover, let it sit 15 mins, then should come right off with the fishing line under it trick. He said mine was probably coming loose like yours is and someone glued it back on. So definately only double sided tape used from ford factory mate. He recommended taking it off using above steps and re tape it all again using 3m automotive double sided tape. Thought I better let u no mate, as my last post to you would of probably put u off the thought of doing it. Good luck!!
  • 1 month later...
thanks heaps for getting back to me mate, I was just going to attack the corners with sika hahah, would of ended up in the same position. I will try the method you have suggested first. thanks again
