  • Dropping a turd
  • Member For: 17y 8m
Its my job, I am payed not to miss things.
Get some recommendations on what settings the fixed sprockets should be. Or get some stock ones and re-install, Stock ones will greatly improve fuel economy at part throttle openings.
  • Dropping a turd
So what parts did you replace?  Didn't you check the timing?
What settings did you use for the cams?
  • Dropping a turd
Look at mine. I couldnt be bothered turning the crank for the markings to line up exact. But you can see that the sprockets are at the correct spacing.
  On 20/06/2018 at 11:51 AM, fgxrsux said:
yeah I got it, I assumed the noise was from the broken guide and tensioner but it looks like the left cam is wayyy out. thanks
Expand
Post an image.
