Benji81 New Member 15 Member For: 6y 10m 5d Posted 10/06/18 06:42 AM Share Posted 10/06/18 06:42 AM Am ordering valve springs for my bf Going to order a upgrade fuel pump aswell From what I have read the walbro 255 is the go Is there a part number for the correct one that fits in falcon? Aiming for 300rwkw will this pump be enough? Thanks benno Or maybe one of these http://www.vpw.com.au/Category/Index/357687 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,358 Member For: 16y 11m 22d Gender: Male Location: Melbourne Posted 10/06/18 08:32 AM Share Posted 10/06/18 08:32 AM Walbro GSS340 255lph is the one you're after and will support 300rwkw as a pickup pump. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 5d Gender: Male Location: Perth Posted 10/06/18 11:53 AM Share Posted 10/06/18 11:53 AM Maybe buy a complete drop in. Easy as, just select the one that suits your model car. STD or big pods options as well. BF2 is a different model https://www.ebay.com.au/itm/FORD-FALCON-BA-BF-XR6-TURBO-XR8-FPV-WALBRO-GSS341-PERFORMANCE-FUEL-PUMP-ASSEMBLY/263164433958?hash=item3d45d29626:g:5~wAAOSwOTVZmpOI https://www.ebay.com.au/itm/FORD-FALCON-FPV-BA-BF-XR6-TURBO-XR8-WALBRO-GSS341-BIG-POD-FUEL-PUMP-PERFORMANCE/263154938361?hash=item3d4541b1f9:g:0XcAAOSwi0JZlrnK Link to comment Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 3m 7d Gender: Male Location: Melbourne Posted 10/06/18 12:13 PM Share Posted 10/06/18 12:13 PM yeop go a complete new drop in. you get all new filters and bits n bobs too. dont bother pulling the old one apart too fiddly and waste of time. 1 Link to comment Share on other sites More sharing options...
adams355 Member 529 Member For: 7y 11m Gender: Male Location: Brisbane Posted 10/06/18 01:56 PM Share Posted 10/06/18 01:56 PM On 10/06/2018 at 11:53 AM, arronm said: Maybe buy a complete drop in. Easy as, just select the one that suits your model car. STD or big pods options as well. BF2 is a different model https://www.ebay.com.au/itm/FORD-FALCON-BA-BF-XR6-TURBO-XR8-FPV-WALBRO-GSS341-PERFORMANCE-FUEL-PUMP-ASSEMBLY/263164433958?hash=item3d45d29626:g:5~wAAOSwOTVZmpOI https://www.ebay.com.au/itm/FORD-FALCON-FPV-BA-BF-XR6-TURBO-XR8-WALBRO-GSS341-BIG-POD-FUEL-PUMP-PERFORMANCE/263154938361?hash=item3d4541b1f9:g:0XcAAOSwi0JZlrnK Expand I was looking at this one from same store. Yes, no, maybe. I had the GSS340 in the big pod but it would hesitate under hard throttle at less than a 1/4 tank of fuel. https://www.ebay.com.au/itm/FALCON-BA-BF-XR6-TURBO-F6-FPV-SNIPER-320-LPH-E85-98-PERFORMANCE-FUEL-PUMP-ASSEM/292332706217?hash=item44106319a9:g:Ek4AAOSwoR9aDN-s Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 5d Gender: Male Location: Perth Posted 10/06/18 02:52 PM Share Posted 10/06/18 02:52 PM (edited) I have the big pod with 460 in 400rwkw F6 on 98. less than 1/4 tank no issues. Racewars 24 seconds full throttle. My other F6 has intank 460 in stock pod with single peirberg on process west surge. 470rwkw on E85 less than 1/4 tank no issues. How much power you got? Iam not familiar with that 320 LPH pump. According to walbro only their 460 is E85 compatible. More needs to be modified to the pod than just being big, especially the return.. Look at the design of the fuel tank. Under hard acceleration all the fuel moves rearwards and upwards. Pod has reduced fuel at the pickup. that's why an external surge is really the best option on high power cars. But the big pod (volume) does seen to solve some of the issue. Edited 10/06/18 03:04 PM by arronm 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,358 Member For: 16y 11m 22d Gender: Male Location: Melbourne Posted 11/06/18 12:51 AM Share Posted 11/06/18 12:51 AM On 10/06/2018 at 1:56 PM, adams355 said: I had the GSS340 in the big pod but it would hesitate under hard throttle at less than a 1/4 tank of fuel. Expand If that was happening, you needed a surge tank. A bigger pod would just mask the issue. 1 Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 14/06/18 12:47 AM Share Posted 14/06/18 12:47 AM On 10/06/2018 at 2:52 PM, arronm said: I have the big pod with 460 in 400rwkw F6 on 98. less than 1/4 tank no issues. Racewars 24 seconds full throttle. My other F6 has intank 460 in stock pod with single peirberg on process west surge. 470rwkw on E85 less than 1/4 tank no issues. How much power you got? Iam not familiar with that 320 LPH pump. According to walbro only their 460 is E85 compatible. More needs to be modified to the pod than just being big, especially the return.. Look at the design of the fuel tank. Under hard acceleration all the fuel moves rearwards and upwards. Pod has reduced fuel at the pickup. that's why an external surge is really the best option on high power cars. But the big pod (volume) does seen to solve some of the issue. I have the same big pod with walbro 460 in my car and at racewars it surged on e85 at about 800 meters with the fuel gauge showing a little under 1/3 tank. Are you saying you were doing the 1000m runs with 1/4 tank and no issues? I did a skid first and then launched pretty much straight away so wonder if I just drained the whole pod? Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 6m 8d Gender: Male Posted 14/06/18 01:15 AM Share Posted 14/06/18 01:15 AM The 460s are known for melting fuse holders and this resistance can cause surge like symptoms. They can run up to 20odd amps and the wiring kits needs to be of the highest quality. The in tank pod also recives the return fuel flow so it’s impossible to drain the pod unless your out of fuel. Surge on a 3rd of a tank if the flow is correct on the pump should’nt in theory occur. In saying that fuel systems are complicated to spec out correctly and problems can and do occur. One 460 at around 400rwkw on e85 is about as far as you would want to push it IMO. On paper it should do more but at that level it should have head room left over for a good safety margin. Check your wiring system/fuse setup Lennox. 1 Link to comment Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 1m 6d Gender: Male Location: Perth Posted 14/06/18 02:06 AM Share Posted 14/06/18 02:06 AM Yeah thanks I thought it was pretty unusual cos I still had so much fuel. Thought maybe it was the higher sides of the swirl pot but I guess not The odd thing is though that I filled it up and it was all sweet againHas never happened again since Link to comment Share on other sites More sharing options...
