Scrotus Member 156 Member For: 16y 10m 3d Gender: Male Location: Adelaide Posted 07/06/18 11:16 AM Share Posted 07/06/18 11:16 AM If anyone has removed the circlip with success can you please let me know how to? Been at this clip for over an hour. Tried scribe, screwdrivers, G-clamping, nothing will move it and there is no holes - its just a piece of metal. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/ Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 19d Gender: Male Location: Perth Posted 07/06/18 11:41 AM Share Posted 07/06/18 11:41 AM What car, pictures?? Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658666 Share on other sites More sharing options...
Scrotus Member 156 Member For: 16y 10m 3d Gender: Male Location: Adelaide Posted 07/06/18 05:11 PM Author Share Posted 07/06/18 05:11 PM That may help. It's off BF. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658667 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 19d Gender: Male Location: Perth Posted 08/06/18 02:16 AM Share Posted 08/06/18 02:16 AM To me that looks like a press fit. Not meant to come off. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658671 Share on other sites More sharing options...
Renton Member 151 Member For: 7y 2m 9d Gender: Male Location: Perth Posted 08/06/18 05:27 AM Share Posted 08/06/18 05:27 AM Need to make sure that cap is pressed or clamped down enough so there's no pressure on that wire ring. Maybe even put a socket between the cap and g-clamp so you're compressing more towards the OD of the cap. Looks like you should be able to get a right angle seal pick in that gap at end the of the ring and force it between the ring and and the groove. If you don't have a seal pick maybe try a sharp wood chisel and try forcing that in between the ring and the top edge of the groove. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658675 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 8m 22d Gender: Male Posted 08/06/18 07:17 AM Share Posted 08/06/18 07:17 AM It surprises me that today's modernity is still not fully understood by some. All you need to know! On 08/06/2018 at 2:16 AM, arronm said: To me that looks like a press fit. Not meant to come off. Expand It comes off! Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658678 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 19d Gender: Male Location: Perth Posted 08/06/18 08:06 AM Share Posted 08/06/18 08:06 AM Well there you go. See I wouldn't waste my time rebuild . I would just buy a new one. OP just needed to do some research like you did. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658680 Share on other sites More sharing options...
Renton Member 151 Member For: 7y 2m 9d Gender: Male Location: Perth Posted 08/06/18 08:47 AM Share Posted 08/06/18 08:47 AM On 08/06/2018 at 7:17 AM, Typhoon said: It surprises me that today's modernity is still not fully understood by some. All you need to know! Expand Google and Youtube are a wonderful thing, aren't they! Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658682 Share on other sites More sharing options...
Scrotus Member 156 Member For: 16y 10m 3d Gender: Male Location: Adelaide Posted 09/06/18 05:19 PM Author Share Posted 09/06/18 05:19 PM On 08/06/2018 at 7:17 AM, Typhoon said: It surprises me that today's modernity is still not fully understood by some. All you need to know! It comes off! Expand Mine does not come off like this, he seems to have enough clearance underneath. Spent 2 hours just trying to get this clip off. I give up. Wreckers $40 used pump it ended up being. Link to comment https://www.fordxr6turbo.com/forum/topic/93978-power-steering-pump-resealing-how-to-remove-the-circlip/#findComment-1658751 Share on other sites More sharing options...
