  • 2 years later...
  • New Member
  • Member For: 4y 4m 12d
would it not be possible to if you were going to take and na motor and boost it and use 100% stock turbo parts also pilfer the turbo'd cars ecu would its normal map not be ready for basic boost?
  • Member For: 7y
Will have to much timming. Needs tune.
Na motor valves are cheese and will melt with nice hot turbo injection.
Valve springs arent much better.
But sure it will run. Your just gambling
  • New Member
I know about the vavle springs being rubbish cheers for the knowledge on the actual valves.
its my understanding that the pistons are also different turbo has recesses for lowering compresion?
  • Member For: 7y
Something something oil pump gears hahahaha.
Expand
This is also correct.
In most cases na have sh*t rods n press gudgon pins in flat top pistons.
Lpg good rods n press fit pin, flat top pistons.
Turbo good rods n full floating gudgeon n pistons with relief.
Then as they move from ba to fg things get better as you would expect. All of this has been posted about a million times. So its not hard to get more specific information on it.
