Zlat347 Member 56 Member For: 6y 9m 1d Posted 30/05/18 01:50 AM Share Posted 30/05/18 01:50 AM Hi guys, What are people doing with there map sensor when upgrading to an aftermarket plenum that doesn't have a provision like the factory plenum? Cheers Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 3m 29d Gender: Male Posted 30/05/18 01:57 AM Share Posted 30/05/18 01:57 AM Which plenum mate? Link to comment Share on other sites More sharing options...
Zlat347 Member 56 Member For: 6y 9m 1d Posted 30/05/18 07:42 AM Author Share Posted 30/05/18 07:42 AM plazmaman one which only has couple vaccum ports on underside. I think on there current series they make a spot for it. This is a older one Link to comment Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 8m 20d Gender: Male Location: Western Sydney Posted 30/05/18 08:04 AM Share Posted 30/05/18 08:04 AM Was gonna say the new plazmaman plenum has a lower map port. Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 3m 29d Gender: Male Posted 30/05/18 08:40 AM Share Posted 30/05/18 08:40 AM get the dimensions of the port hole and threat size from the standard upper plenum and take it to a head reconditioning shop/machine shop and problem solved. If possible keep it in the same standard location so you dont need to extend the wiring loom. Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 7m 28d Gender: Male Location: Central Queensland Posted 31/05/18 10:57 AM Share Posted 31/05/18 10:57 AM I ran a flexible line and positioned it next to the ABS module. Link to comment Share on other sites More sharing options...
