Muzz1984 New Member 19 Member For: 8y 2m 9d Posted 28/05/18 07:39 PM Share Posted 28/05/18 07:39 PM Can I get some opinions of the best filter kit? currently tossing between earls and aeroflow Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 13d Gender: Male Location: Perth Posted 28/05/18 09:23 PM Share Posted 28/05/18 09:23 PM What model car? Link to comment Share on other sites More sharing options...
Muzz1984 New Member 19 Member For: 8y 2m 9d Posted 28/05/18 11:22 PM Author Share Posted 28/05/18 11:22 PM 2010 fg xr6t Link to comment Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 5m 16d Gender: Male Posted 29/05/18 12:35 AM Share Posted 29/05/18 12:35 AM If your engine is in good condition and you know it has had regular oil changes and its clean inside then you can get away with not running one. make sure OEM oil line feed filter has been removed and just change your oil and filter every 5000kms At least that's what I do. You may want to ensure that the OEM oil supply line is not clogged up or shows signs of baking first. I know of many workshops that set it up this way. My local turbo shop also recommends this too set up too. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 4m 13d Gender: Male Location: Perth Posted 29/05/18 04:17 AM Share Posted 29/05/18 04:17 AM As Typhoon said , you dont really need one, just remove the factory screen filter. If you feel you want one. Get one with NO crimp fittings, no clear sleeve on the braid and a heatproof sleeve at the turbo end. I get mine from GJ drivelines. Give them a call. I buy black as its stealth. https://www.gjdrivelines.com.au/performance-plumbing Link to comment Share on other sites More sharing options...
