  • New Member
  • Member For: 7y 3d
Just wondering what the aeroflow intercooler 600 x300x76 to suit ba/f is good for hp wise
I can get one cheap that's new in box
I have a bf turbo stock atm but planning on mods
Have just hooked up a trans cooler with fan for the zf
Valve springs and injectors next then high flow cat
I plan on fabricating my own cold air induction (moving battery)
And pipe work to suit what ever intercooler I buy
Looking for a reliable 300rwkw
Is this intercooler up for it?
Thnks in advance
Benno
https://www.fordxr6turbo.com/forum/topic/93949-aeroflow-intercooler/
  • FREAKY
  • Member For: 15y 5m 5d
yo benno
I didnt even know they made coolers. steer clear
anyways
stick with the proven brands mate. plaz or pw stage 1s will be enough for 300kw.
  • Member For: 10y 4m 1d
  • Gender: Not Telling
That cooler will do 300rwkw all day long. It'll likely go better than 450rwkw.
Plenty of big ebay bar and plate coolers doing 700+whp for just a few hundred bucks. You just gotta mess around fitting it as that stuff doesn't come in kit form.
Plaz hot and cold piping will fit most side entry coolers.
  • Dropping a turd
  • Member For: 17y 7m 3d
That cooler will be fine.  Pipe work will have to be made.  Check the area.  You may need the 450mm wide option. 600mm may foul on the body work .  Remember 600mm will be the core size. Total width will include tanks
Depends on what you can make.
Why done you install turbo side intake , relocate the battery and install Process west throttle body relocation
Edited by arronm
  • New Member
  • Member For: 7y 3d
Cheers for replies
Aeroflow say no body mods to fit but I will measure up next time front bumper is off
Ive used aeroflow stuff for years
Never had a problem quality is fairly good so not wondered about brand more about size
First time playing with turbo stuff so still learning
