Typhoon Member 564 Member For: 20y 8m 6d Gender: Male Posted 27/05/18 11:58 AM Share Posted 27/05/18 11:58 AM On 27/05/2018 at 9:54 AM, k31th said: shouldn't be mineral oil. should be semi-synthetic. Expand lol could be a worn timming chain guide get the front cover off, guide and crank sproket will be done at those kms could be many things flex plate bolt maybe Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658224 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 28d Gender: Male Location: Brisbane Posted 27/05/18 12:21 PM Share Posted 27/05/18 12:21 PM Add belt tensioner and idler pulley to list Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658226 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 8m 6d Gender: Male Posted 27/05/18 12:27 PM Share Posted 27/05/18 12:27 PM ^^ correct it wouldn’t be a dud lifter, motor would run rough. shouldn’t be the crank, rods pins etc. its likely a simple problem super hard to diagnose over the net buddy Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658228 Share on other sites More sharing options...
sirhazchem New Member 11 Member For: 7y 2m 13d Posted 27/05/18 12:48 PM Author Share Posted 27/05/18 12:48 PM Okay it's a solid knocking not a squeak sounds like it's coming from that head. Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658229 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 28d Gender: Male Location: Brisbane Posted 27/05/18 12:53 PM Share Posted 27/05/18 12:53 PM (edited) yea, that's what bad belt tensioner sounds like. It sounds like its coming from head. Check first, might be lucky. Edited 27/05/18 12:56 PM by adams355 Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658230 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 8m 6d Gender: Male Posted 27/05/18 12:53 PM Share Posted 27/05/18 12:53 PM good luck buddy Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658231 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m Gender: Not Telling Posted 27/05/18 01:17 PM Share Posted 27/05/18 01:17 PM Does an oil change, hears lifter noise, removes sump, hears knocking. On 27/05/2018 at 12:53 PM, Typhoon said: good luck buddy Expand This ^ On what planet do you remove the sump after a standard oil change, having On 26/05/2018 at 5:43 AM, sirhazchem said: done hundreds of times before Expand with no prior issues??? This reeks of 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658234 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 8m 6d Gender: Male Posted 27/05/18 02:27 PM Share Posted 27/05/18 02:27 PM agree - or at least absolute stupidity Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658238 Share on other sites More sharing options...
sirhazchem New Member 11 Member For: 7y 2m 13d Posted 28/05/18 05:38 AM Author Share Posted 28/05/18 05:38 AM I was lead to believe blocked pickup reduction in oil availability to the top of the engine cause the knock. Sump removal is cheapest option oil and some black maxxxxx is why I went that route rather than changing parts one after the other. Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658270 Share on other sites More sharing options...
Typhoon Member 564 Member For: 20y 8m 6d Gender: Male Posted 28/05/18 06:27 AM Share Posted 28/05/18 06:27 AM If the pick up is blocked then your motor is full of sludge anyway and its on its last legs. I would have taken off the valve cover before the sump. Pop it off, see sludge then put motor in the bin. If the sumps been off before or changed then the pick up height could have been effected. do a compression check and if that's all good then take it to Ford to have them look at it and be prepared to pay $$$$$$$$$$s Link to comment https://www.fordxr6turbo.com/forum/topic/93948-g6et-knocking/page/2/#findComment-1658275 Share on other sites More sharing options...
