Bf2 XR6 Turbo Fuel line issuew
  • New Member
  • Member For: 6y 9m 10d
Hey guys so today while doing my service ive changed the fuel filter that looks like its been there since new, and in doing that it mustve caused damage to the line running to either side of the filter, although I cant find anywhere that sells them, id prefer to go upgraded lines rather than replacing with another set of standard ones
Does it make a difference if I change them from pipes to braided lines?
  • Dropping a turd
  • Member For: 17y 3m 18d
Both sections of pipe that screws into the filter can be bought from Ford.  If over tightened the Male threads distort and then pickup inside filter.
The key is to nip up the nuts then start up car.  Then just tighten enough to stop leaks.
Engine side is long , fuel tank side is only about 150mm
https://m.ebay.com.au/itm/GENUINE-FORD-BA-BF-FALCON-4-0-SEDAN-UTE-FUEL-FILTER-LINE-PIPE-ENGINE-TO-FILTER/302173221704?epid=2115249494&hash=item465aed7348:g:uxYAAOSwJ7RYWw3~
Edited by arronm
