Matthew26supa6 New Member 5 Member For: 6y 6m 8d Posted 22/05/18 01:17 PM Share Posted 22/05/18 01:17 PM Hi guys just blew up my n/a ba motor and instead of rebuilding it ive found a xr6 turbo motor out of a ba for $2,500 for everything. Including turbo cat all piping ect. Will there be any problems ill strike installing this motor or will it be plug and play. It also comes with the pcm (computer) ?? Cheers in andvance guys Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 9m 5d Gender: Male Location: Frankston, 3199 Posted 22/05/18 01:32 PM Share Posted 22/05/18 01:32 PM A browse through @NA_TURBO's thread may give some ideas Link to comment Share on other sites More sharing options...
Matthew26supa6 New Member 5 Member For: 6y 6m 8d Posted 22/05/18 01:39 PM Author Share Posted 22/05/18 01:39 PM Yeah just had a look than couldnt find what The answer I want ? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 1m 23d Gender: Male Location: Mildura Posted 22/05/18 07:34 PM Share Posted 22/05/18 07:34 PM Happy to answer any questions.Is your car a BA or BF? Make sure that the engine and ecu are out of the same model car as there is slight differences between the two.Everything will bolt into yours, but will need to be taken to Ford to get the ecu mated with your cars abs and security modules.Power steering cooler will need to be moved as it will be in the way of the intercooler, turbo models had it mounted at the top of the radiator not the bottom. Also you'll need a turbo model exhaust put on. Put new XR6 turbo engine mounts on as non turbo one's are different and will break. 1 Link to comment Share on other sites More sharing options...
Matthew26supa6 New Member 5 Member For: 6y 6m 8d Posted 22/05/18 10:45 PM Author Share Posted 22/05/18 10:45 PM Thanks na turbo. So seems straight forward than. I have a flash tuner. Can I fix the abs and security with that or will it still have to be taken to ford?? I havent used it yet ? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 1m 23d Gender: Male Location: Mildura Posted 23/05/18 02:31 AM Share Posted 23/05/18 02:31 AM I would say ford would need to use their equipment to do that, they did on mine when we loaded a turbo tune on my ecu, the abs wouldn't communicate with my ecu. But that's my experience anyway. Link to comment Share on other sites More sharing options...
Matthew26supa6 New Member 5 Member For: 6y 6m 8d Posted 23/05/18 02:58 AM Author Share Posted 23/05/18 02:58 AM Alright ill see how we go. Cheers mate Link to comment Share on other sites More sharing options...
ADZzzz New Member 2 Member For: 6y 3m 1d Posted 18/10/19 07:00 PM Share Posted 18/10/19 07:00 PM Hi swap abs pump swap dash wiring icc unit engine bay wiring fuse box just about everything I have run into all these problems and reverse map sensor wiring to hope this helps Link to comment Share on other sites More sharing options...
