Typhoon Member 564 Member For: 20y 6m 21d Gender: Male Posted 30/04/18 09:51 PM Share Posted 30/04/18 09:51 PM On 30/04/2018 at 11:57 AM, demon1300 said: Quite interested in this thread atm as I'm looking for a solution for mine before the 42 goes on. I was recently looking at the new Process West sepr8r cans they've developed. They're a true scrubber with washable element and also have a pressure release valve and drain. Only issue for me is the fact they're -8 inlet/outlet only as well as only one inlet... Either way, looks like a nicely developed kit that would definitely keep the fuzz happy! Expand Speaking to AMC Performance about my catch can solution. They tell me they did back to back testing on a 1000hp monster running 9.2 1/4 mile. -6 is to small (roughly OEM) -8 is ok as tested on the monster 1000hp car -10 is best. Both -8 and -10 tests were done in 3 port pumb back and vent to atmo setups. -8 with baffling / a filtration system could be a bit small, depending on how much and how long the air is slowed down. -10 setup vent to atmo is the preferred solution based on my research. Dion Amato Dyno Mite Performance tells me the barra is not a huge breather engine, and even the most basic setup catch can solutions seem to work ok. hope this helps Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1656540 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 17d Gender: Male Location: Perth Posted 01/05/18 03:41 AM Share Posted 01/05/18 03:41 AM How much is the process west ? Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1656547 Share on other sites More sharing options...
demon1300 Member 435 Member For: 13y 2m 4d Gender: Male Posted 01/05/18 11:58 AM Share Posted 01/05/18 11:58 AM Was quoted $350 for the can and bracket. Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1656564 Share on other sites More sharing options...
Muzz1984 New Member 19 Member For: 8y 3m 10d Posted 10/06/18 04:17 PM Share Posted 10/06/18 04:17 PM Can I get some advice on this setup.... have breatherr can connected to turbo side intake then to catch can and on to breather orignal pcm valve is still connected to vacuum system And what happens if I run both breathers to catch can Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1658806 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 17d Gender: Male Location: Perth Posted 10/06/18 05:38 PM Share Posted 10/06/18 05:38 PM (edited) Plumbing is correct. Is the catch can baffled ? Its illegal to vent the can to atmosphere. You can run both breather and PCV to the can. It just cant be plumbed back in. It must vent through the can top filter. Edited 10/06/18 05:43 PM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1658807 Share on other sites More sharing options...
Muzz1984 New Member 19 Member For: 8y 3m 10d Posted 11/06/18 04:42 AM Share Posted 11/06/18 04:42 AM Can has filter on top but I have plugged it so it no longer breaths through filter will removing pcm and vacuum effect idle?? So currently have 1 breather to catch can and from there to turbo side intake wondering should I connect both breather and vacuum pvc to catch can and then what do I do about intake connection? Just block it? Or get a T piece adapter so both breathers connect to catch can and catch can still runs to turbo side intake? Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1658824 Share on other sites More sharing options...
Muzz1984 New Member 19 Member For: 8y 3m 10d Posted 11/06/18 12:13 PM Share Posted 11/06/18 12:13 PM Also what do mean mean by baffled??! So currently have 1 breather to catch can and from there to turbo side intake wondering should I connect both breather and vacuum pvc to catch can and then what do I do about intake connection? Just block it? Or get a T piece adapter so both breathers connect to catch can and catch can still runs to turbo side intake? And what effect does not having vacuum connect to pvc valve at rear? Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1658844 Share on other sites More sharing options...
Rushy90 New Member 4 Member For: 6y 28d Posted 19/03/19 09:31 PM Share Posted 19/03/19 09:31 PM Hi mate. just wondering how you went with your set up? im looking at something similar cheers Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1679299 Share on other sites More sharing options...
Goeer Banned 537 Member For: 9y 1m 28d Gender: Male Location: South Australia Posted 19/03/19 11:15 PM Share Posted 19/03/19 11:15 PM I have a Herrod oil breather / separator, but the problem is, I don't know what it looks like or what it does. All I know is, it is the pressure from the engine passing through the head and capturing it before it vents to the atmosphere. And also before it clogs your plenum. That's what there used for. I THINK. Also, it will stop your oil galleries from becoming blocked. That = destroyed engine. Oil galleries are just the little bits and pieces that oil has to flow through. Its like a labyrinth in side your motor. A maze, in other words. I think I might be talking sh*t. This is the first forum where the time clock matches reality. Link to comment https://www.fordxr6turbo.com/forum/topic/93881-oil-catch-can-tips/page/4/#findComment-1679307 Share on other sites More sharing options...
