bbq_xr6 New Member 5 Member For: 8y 6m 9d Posted 16/04/18 08:45 AM Share Posted 16/04/18 08:45 AM High pressure power steering hoses are a common failure on many cars, after changing mine today made me curious why the FG XR6t has such a complex abomination of a power steering hose? Three high pressure hydraulic hoses, six high pressure fittings for the supply side. Looks like it could easily be re-engineered as a single high pressure hose with two fittings. Also a crimped fitting on the return side 10cm from the attachment of the power steering cooler. Does anyone know why it's got so many parts to it for seemingly no reason? Here's a photo of one https://www.ebay.com.au/itm/Power-Steering-Hose-Fits-Ford-Falcon-FG-4-0L-6Cyl-XR6-Turbo-06-08-11-11-Ser-1/272977004738 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,959 Member For: 16y 7m 9d Gender: Male Location: Melbourne Posted 16/04/18 09:06 AM Share Posted 16/04/18 09:06 AM why is the diff bush the most common point of failure? same reason, probably; ultimately bottom line $$ outweighs the design principles of engineers... so corners are cut from an engineering point of view. Link to comment Share on other sites More sharing options...
bbq_xr6 New Member 5 Member For: 8y 6m 9d Posted 16/04/18 09:59 AM Author Share Posted 16/04/18 09:59 AM (edited) I'd like to agree, but this absolutely isn't cutting corners. There's has to be a very good reason but I have no idea what. Such a complex contraption is adding a couple of hundred dollars per car. Making it harder to assemble. Costing much more in raw materials. Adding 3x more failure points. Even by the factory stage, it would be far cheaper to scrap a years inventory and redesign it to single high pressure flex than continue using this monstrosity. Edited 16/04/18 10:00 AM by bbq_xr6 Link to comment Share on other sites More sharing options...
