powelmac Member 32 Member For: 9y 2m 23d Posted 13/04/18 11:09 PM Share Posted 13/04/18 11:09 PM Having traction issues with my lowered manual F6 ute. Tyres are still 245/35r19, when it wasn't lowered I had better traction as the rear could squat, however now its 50mm lowered with reset herrod leaf springs and an anti-tramp leaf on the top I just can't get traction in 2nd even only on the 98 tune with 327rwkw and new tyres. Does the stiff rear end reduce traction significantly? Might be worth checking out a wider rim/tyre I'm guessing Also broke the water pump pulley last night after being humiliated by a BMWs1000rr Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/ Share on other sites More sharing options...
FiftyOne Bronze Donating Members 1,145 Member For: 12y 5d Gender: Male Posted 14/04/18 02:23 AM Share Posted 14/04/18 02:23 AM One variable you've taken out of the mix with the lowering has been arresting shock. If you hit a bump in the road now you have reduced the time & distance you have to work with arresting that energy, therefore you get a firmer or rougher ride. Similarly you are trying to rapidly load the tyre and with the way geometry & physics work, you are loading that axle. Without some of the distance & flex you originally had, the tyre will still only handle so much torque but you are getting to the friction limit of the rubber really quick. You don't reduce the traction so much as make it difficult to feel when you are coming up on that limit. Once you've smashed through the limit of friction to the road it becomes a loosing struggle. Basically if you can get your head around friction, adding more tyre grip will only offer so much. See static & kinetic friction here https://en.wikipedia.org/wiki/Friction#Static_friction Also think about a top fueler, they have no rear suspension and they bring on way more power quicker than you can dream of. But the tyres go through all sorts of crazy deformation. Have a look at the video below about bike frame stiffness, semi relatable? Hope if haven't confused anything for you. In answer to your question, yes a wider stickier tyre may help with more overall grip. However if you think of that graph of friction you potentially still break traction and still loose heaps of grip very quickly. I would lift it and make it a little nicer ride, but that's just me. Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1655584 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 2m 5d Gender: Male Location: Western Sydney Posted 14/04/18 03:11 AM Share Posted 14/04/18 03:11 AM Stickier tyres will fix it. As wide as possible helps. If it tramps then get some caltracs or mal woods anti tramp kit. Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1655587 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 4m 25d Gender: Male Location: SW Sydney Posted 14/04/18 03:33 AM Share Posted 14/04/18 03:33 AM @powelmac very interested in whether the half leaf got rid of your tramp 100% Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1655588 Share on other sites More sharing options...
powelmac Member 32 Member For: 9y 2m 23d Posted 18/04/18 07:28 AM Author Share Posted 18/04/18 07:28 AM Thanks @FiftyOne that's some good insight, I guess it's looks vs performance. Im going to try a set of wider rears and see if that works first then I guess I'll need to revise the suspension height if that fails. @camo86TI tried new revalved bilsteins, and different bushes etc which did nothing, half leaf got rid of it 100%, can accelerate and dump the clutch now and just spins compared to a trampoline like motion previously 2 Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1655881 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 6m 11d Gender: Male Location: Melbourne Posted 20/04/18 02:36 AM Share Posted 20/04/18 02:36 AM (edited) go buy some decent tyres, or go get some 18x10s with fat sticky tyres. no bob jane specials. end of the day its a ute with 1950's rear end dont expect it to be all that great. whats this half leaf wizardry? pics? Edited 20/04/18 02:37 AM by Ford Freak Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1656000 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m 10d Gender: Male Location: Perth Posted 20/04/18 04:15 AM Share Posted 20/04/18 04:15 AM Yep coil springs were used in cars since 1906. Ford obviously just loved the horse and buggy. Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1656005 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 6m 11d Gender: Male Location: Melbourne Posted 20/04/18 04:44 AM Share Posted 20/04/18 04:44 AM this guy knows^^ ford ute suspension carried over from these no joke Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1656008 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 12y 2m 5d Gender: Male Location: Western Sydney Posted 20/04/18 07:06 AM Share Posted 20/04/18 07:06 AM If you want to be specific to how old, half of the bushes for the utes rear end are XT parts. Farking old. Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1656015 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 6m 11d Gender: Male Location: Melbourne Posted 20/04/18 07:29 AM Share Posted 20/04/18 07:29 AM (edited) yer they havent spent a cent on the rear end. really dissapointing. but they always saw the ford ute to be a workhorse to carry a load, where h.olden see the ss ute as a 2 door sports car hahah. Edited 20/04/18 07:29 AM by Ford Freak Link to comment https://www.fordxr6turbo.com/forum/topic/93859-manual-ute-traction/#findComment-1656016 Share on other sites More sharing options...
