MUZz1984@ New Member 22 Member For: 6y 7m 20d Posted 12/04/18 01:02 PM Share Posted 12/04/18 01:02 PM On 4/11/2018 at 7:25 PM, JETURBO said: If keeping it under 550rwkw or 23ish psi you don’t have to... What do you know about xr6t perminace upgradea? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,920 Member For: 9y 10m Gender: Male Location: South Australia Posted 12/04/18 01:13 PM Share Posted 12/04/18 01:13 PM #gregnant Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 1m 2d Gender: Male Location: Perth Posted 12/04/18 01:50 PM Share Posted 12/04/18 01:50 PM (edited) If you are going to rev it up , get a forged harmonic balancer not a cast one.. Why dont you try and find a brand new FG short motor.. It will handle the power you want.. Edited 12/04/18 01:52 PM by arronm Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 29d Gender: Male Location: Adelaide Posted 12/04/18 11:39 PM Share Posted 12/04/18 11:39 PM I agree with @HI PSI Re: JE pistons, love them and they’re all made per batch and a serial code applied so if you ever destroy one piston you can get an exact replacement ! LOLWUT @MUZz1984@ Agree with @arronm for a cost effective solution regarding a new FG short is ~$3500 and can happily sit in the 500rwkw area as is Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 8m 3d Posted 09/05/18 10:40 AM Author Share Posted 09/05/18 10:40 AM Engine's back, mostly went with JETS suggestions, JE pistons (+0.020) scat rods, arp studs (head & main) atomic oil pump gears & cover (ported myself after brad said where to enlarge) atomic chain, guides & bottom cog, balancer & flex plate. Torque plate bored & honed , file back rings straighten crankshaft (!) plaz valve springs, ford exhaust valves & head gasket & new heat exchanger. It's mostly back together & intending to change it over this weekend 3 Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 11m 1d Gender: Not Telling Posted 09/05/18 10:59 PM Share Posted 09/05/18 10:59 PM that's sick man keen as to see the result! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 29d Gender: Male Location: Adelaide Posted 10/05/18 02:02 AM Share Posted 10/05/18 02:02 AM Piks !!! 1 Link to comment Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 10y 8m 3d Posted 12/05/18 07:25 AM Author Share Posted 12/05/18 07:25 AM It's in & running fine, started at 5am this morning & in & running at 1.30! dropped the whole lot out the bottom & changed every thing over to the new engine. That went smooth but changing the radiator- what a crap job (worse than BA_BF) have pics will upload later. Thanks for all the advice! 1 Link to comment Share on other sites More sharing options...
Renton Member 151 Member For: 6y 7m 23d Gender: Male Location: Perth Posted 12/05/18 11:03 AM Share Posted 12/05/18 11:03 AM Link to comment Share on other sites More sharing options...
HI PSI Member 1,586 Member For: 18y 6m 4d Gender: Male Location: Central Queensland Posted 13/05/18 04:51 AM Share Posted 13/05/18 04:51 AM Here are a new set of 0.020" JE forged pistons that have coated skirts and ceramic tops. I picked them up for $1300. There are bargains out there..... 4 Link to comment Share on other sites More sharing options...
