MUZz1984@ New Member 22 Member For: 7y 1m 8d Posted 12/04/18 01:02 PM Share Posted 12/04/18 01:02 PM On 11/04/2018 at 9:25 AM, JETURBO said: If keeping it under 550rwkw or 23ish psi you don’t have to... Expand What do you know about xr6t perminace upgradea? Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1655448 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 19d Gender: Not Telling Posted 12/04/18 01:13 PM Share Posted 12/04/18 01:13 PM #gregnant Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1655449 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 21d Gender: Male Location: Perth Posted 12/04/18 01:50 PM Share Posted 12/04/18 01:50 PM (edited) If you are going to rev it up , get a forged harmonic balancer not a cast one.. Why dont you try and find a brand new FG short motor.. It will handle the power you want.. Edited 12/04/18 01:52 PM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1655450 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 17d Gender: Male Location: Adelaide Posted 12/04/18 11:39 PM Share Posted 12/04/18 11:39 PM I agree with @HI PSI Re: JE pistons, love them and they’re all made per batch and a serial code applied so if you ever destroy one piston you can get an exact replacement ! LOLWUT @MUZz1984@ Agree with @arronm for a cost effective solution regarding a new FG short is ~$3500 and can happily sit in the 500rwkw area as is Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1655451 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 21d Posted 09/05/18 10:40 AM Author Share Posted 09/05/18 10:40 AM Engine's back, mostly went with JETS suggestions, JE pistons (+0.020) scat rods, arp studs (head & main) atomic oil pump gears & cover (ported myself after brad said where to enlarge) atomic chain, guides & bottom cog, balancer & flex plate. Torque plate bored & honed , file back rings straighten crankshaft (!) plaz valve springs, ford exhaust valves & head gasket & new heat exchanger. It's mostly back together & intending to change it over this weekend 3 Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1656993 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 4m 20d Gender: Not Telling Posted 09/05/18 10:59 PM Share Posted 09/05/18 10:59 PM that's sick man keen as to see the result! Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1657015 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 11m 17d Gender: Male Location: Adelaide Posted 10/05/18 02:02 AM Share Posted 10/05/18 02:02 AM Piks !!! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1657043 Share on other sites More sharing options...
4321 Bronze Donating Members 257 Member For: 11y 1m 21d Posted 12/05/18 07:25 AM Author Share Posted 12/05/18 07:25 AM It's in & running fine, started at 5am this morning & in & running at 1.30! dropped the whole lot out the bottom & changed every thing over to the new engine. That went smooth but changing the radiator- what a crap job (worse than BA_BF) have pics will upload later. Thanks for all the advice! 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1657192 Share on other sites More sharing options...
Renton Member 151 Member For: 7y 1m 12d Gender: Male Location: Perth Posted 12/05/18 11:03 AM Share Posted 12/05/18 11:03 AM Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1657220 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 23d Gender: Male Location: Central Queensland Posted 13/05/18 04:51 AM Share Posted 13/05/18 04:51 AM Here are a new set of 0.020" JE forged pistons that have coated skirts and ceramic tops. I picked them up for $1300. There are bargains out there..... 4 Link to comment https://www.fordxr6turbo.com/forum/topic/93848-fg-engine-rebuild/page/2/#findComment-1657253 Share on other sites More sharing options...
