3Katz Donating Members 122 Member For: 7y 2m 25d Posted 09/04/18 09:29 AM Share Posted 09/04/18 09:29 AM Hi, I am in the process of fitting a turbo engine to my RTV and have a question. The sedan I've taken the engine from was a conversion as well and I'm not sure on this vac line. The sedan had this fitting which I thought was a check valve (it's not) and my ute had this straight through connector. I've traced the hose and it goes back to the fuel tank. Shouldn't there be a check valve to stop boost pressure finding it's way to the tank? I imagine the brake booster hose should have a check valve as well? Thanks guys Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 7d Gender: Male Location: Perth Posted 09/04/18 09:37 AM Share Posted 09/04/18 09:37 AM The charcoal cannister line has a solenoid valve that only opens on cruise so no checks valve required. (next to the ac accumulator in your first pic) Booster has an internal check valve Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655272 Share on other sites More sharing options...
3Katz Donating Members 122 Member For: 7y 2m 25d Posted 09/04/18 09:42 AM Author Share Posted 09/04/18 09:42 AM Awesome! Thank you! Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655275 Share on other sites More sharing options...
3Katz Donating Members 122 Member For: 7y 2m 25d Posted 14/04/18 06:07 AM Author Share Posted 14/04/18 06:07 AM (edited) I got it all running and driving, it's in limp mode which can only be expected after coming from a sedan with abs and traction control, should be an easy enough fix at a tuner or Ford I guess. I have another question about this vacuum hose with the blue fitting in the picture below. I'm assuming it goes to a vacuum tank which stores vacuum for the n/a engines intake butterflies and also the diff lock on the RTV's? It doesn't seem to have a check valve but does it have some other control to prevent it receiving boost pressure? I will be needing vacuum to engage diff lock, even more so nowbut don't want to hook it up without knowing... Edited 14/04/18 06:15 AM by 3Katz Pics wrong Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655594 Share on other sites More sharing options...
3Katz Donating Members 122 Member For: 7y 2m 25d Posted 14/04/18 06:21 AM Author Share Posted 14/04/18 06:21 AM Crikey. Messed it all up on my phone let me try pics again. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655597 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 11m 29d Gender: Male Location: Western Sydney Posted 14/04/18 06:35 AM Share Posted 14/04/18 06:35 AM Awesome Ute mate, very nice.Built what Ford should have. Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655602 Share on other sites More sharing options...
3Katz Donating Members 122 Member For: 7y 2m 25d Posted 14/04/18 07:58 AM Author Share Posted 14/04/18 07:58 AM Thanks mate, will be nice to give it a proper test once I have more gears than just 3rd. Link to comment https://www.fordxr6turbo.com/forum/topic/93844-turbo-conversion-problem/#findComment-1655604 Share on other sites More sharing options...
