Process West surge tank, FG manifold & FG TB elbow
OZYWALKER
  • XR50T
  • Member For: 11y 8m 12d
The following parts are for sale, all removed in working order as they were replaced with upgrades.
- Process West fuel system - $1400
Consists of the new Process West surge tank with dual walbro 460 pumps. Process West Billet fuel rail, quick connect to factory line fittings, dual -6AN supply with check valves at the tank outlets, -8AN return line with a turbosmart FPR2000 and 100psi gauge (gauge reads correctly but has a crack in the glass).
- FG Turbo Inlet manifold - $400
- Throttle body elbow $400
From a Jonny Tig cooler kit, would probably suit other setups. Has a Turbosmart dual port 38mm BOV with blocking cap, trumpet and recirculation fitting. Also has a Nizpro overboost valve fitted to it.
Pickup in western Sydney prefered, if postage is required there may be a day or so delay as I'm not able to drive currently.
  • Dropping a turd
  • Member For: 17y 2m 17d
47 minutes ago, Ralph Wiggum said:
Why do you need an fg fuel rail.......?
Yep realised that after I posted.  But didn't want to repost.  Best to sell as a package Any rate.
I need a rail when I add the second pierberg.
  • Moar Powar Babeh
  • Member For: 19y 3m 21d
37 minutes ago, OZYWALKER said:
Not specifically an FG rail, I'm pretty sure the bracket also suit the b series.
Brackets don't fit b series unfortunately
GLWS
If splitting rail from kit becomes feasible hmu
Edited by Ralph Wiggum
  • Member For: 20y 3m 21d
Mate what will you upgrade to?
This fuel system should go 650rwkw on E85.
You must be chasing more power I can only assume?
Edited by Typhoon
  • XR50T
Want these gone asap.
Fuel system $1000
Manifold $300
Throttle elbow $300
Also have a battery relocation kit up for grabs (free), needs hardware to mount the tray, has a battery clamp that's not in the pic. The battery is gonna cost a box of beer.
Guest
This topic is now closed to further replies.
