red80 New Member 12 Member For: 7y 10m Posted 04/04/18 05:48 AM Share Posted 04/04/18 05:48 AM I'm running a BF turbo engine for an engine conversion and need to calibrate the coolant temp and oil temp to the Haltech ECU. Does anyone have the resistance charts for these? I.e. 0 deg = 10ohms - 80 deg = 0ohms or whatever it may be Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/ Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 24d Gender: Male Location: Central Queensland Posted 08/04/18 01:04 PM Share Posted 08/04/18 01:04 PM I installed new AEM sensors for this exact reason. I seem to remember my wiring guy saying something about them being GM style sensors. Could be wrong though, as it was a while ago. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655238 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 08/04/18 01:15 PM Share Posted 08/04/18 01:15 PM Whoops I did mean to do some digging but I forgot. On 08/04/2018 at 1:04 PM, HI PSI said: I installed new AEM sensors Expand Yeah I was going to suggest just buying new sensors as running 12 year old sensors on a new build/ecu is just not what you should do. Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655241 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 26d Gender: Male Location: Perth Posted 08/04/18 03:21 PM Share Posted 08/04/18 03:21 PM Sensors could be new and being used for ease of installation? Eot is in the linked doc interesting the Cht is not listed. https://www.dropbox.com/s/dmw5g4n2yek2ir8/303-14 Powertrain Control Management.pdf?dl=0 Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655246 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 08/04/18 03:24 PM Share Posted 08/04/18 03:24 PM That they could be. Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655247 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 22d Gender: Male Location: Perth Posted 08/04/18 04:34 PM Share Posted 08/04/18 04:34 PM There is no coolant temp. The sensor doesnt touch liquid. Its head temperature.. Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655249 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 26d Gender: Male Location: Perth Posted 09/04/18 12:38 AM Share Posted 09/04/18 12:38 AM CHT = cylinder head temp r r Ron. Either way they don't list specs for it Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655257 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 3m 20d Gender: Not Telling Posted 09/04/18 03:01 AM Share Posted 09/04/18 03:01 AM The mighty car mods dudes used a haltech in their barra cressida with the factory wiring harness. Turbo Yoda sorted out the harness and they got it tuned at Castle Hill Performance. You could email any or all of these guys and I don't see why they wouldn't help you out. Of course you could just plot your own curves. Nothing that a multi-meter, a freezer and a pot of water on the stove wouldn't fix. Here is a discussion about that kind of stuff. Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655259 Share on other sites More sharing options...
red80 New Member 12 Member For: 7y 10m Posted 12/04/18 05:15 AM Author Share Posted 12/04/18 05:15 AM oil temp easy swapped if need be but head temp is a brand new sensor as they are a pain to get to if it fails Haltech use GM style sensors but by the time you buy a bunch of them they add up. Trying to spend money in the right areas without going overboard with new everything. Was going to plot the temps as suggested with a spare sensor and I figure the oil temp would give a good indication of engine temp. Does the Barra actually have a sensor for coolant? Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655434 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 22d Gender: Male Location: Perth Posted 12/04/18 05:40 AM Share Posted 12/04/18 05:40 AM (edited) No, Why dont you use a VDO sensor and run it into the coolant in the top hose. https://vdo-webshop.nl/en/34-temperature-sensors Edited 12/04/18 05:46 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/93829-resistance-for-coolant-and-oil-temp-sensors/#findComment-1655435 Share on other sites More sharing options...
